danjperron wrote: ↑Sun Aug 29, 2021 11:16 am
I tried doing so but it appears that my /etc/network/interfaces.d folder is completely empty
This is normal. You need to fill it yourself!
Enter this command and your text.
sudo nano /etc/network/interfaces.d/wlan1
auto wlan1
allow-hotplug wlan1
iface wlan1 inet dhcp
If "wlan1" is already visible with the command "ifconfig" then you need to set wpa_supplicant.
Enter the essid and password in /etc/wpa_supplicant/wpa_supplicant.conf
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
; (I'm in Canada then put your country abbreviation)
country=CA
network={
ssid="put your essid there"
psk="put your password there"
b.t.w since you have wlan0, it should be wise to create another wpa_supplicant.conf like wpa.supplicant.wlan1.conf for your second wifi.
Just specify that one instead in your /etc/network/interfaces.d/wlan1 file,
What is wrong with wlan0 ??? Why do you need another wifi ???
Thanks for this. It helped me out, but I see a weird issue going on. I am getting 2 IP addresses from my DHCP server. I can only ssh to the raspberry pi via the second IP. I need the stop the raspberry pi from getting the second IP address on a single wlan interface.
I am using Bullseye 32-bit on raspberry pi 3b. I compiled the kernel module as per instructions in this thread. I have onboard WiFi disabled as it was causing system crashes. The USB dongle is not causing crashes.
output of uname -srm:
output of ifconfig:
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.12 netmask 255.255.255.0 broadcast 192.168.1.255
output of ip addr:
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 7c:c2:c6:17:0a:15 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.12/24 brd 192.168.1.255 scope global dynamic wlan0
valid_lft 35334sec preferred_lft 35334sec
inet 192.168.1.22/24 brd 192.168.1.255 scope global secondary dynamic noprefixroute wlan0
valid_lft 35334sec preferred_lft 30834sec
What is going on with that secondary IP address? I don't want it assigned. I did try to remove /etc/network/interfaces.d/wlan0 but then I get no IP address at all. I also tried placing denyinterfaces wlan0 in /etc/dhcpcd.conf but once again no IP address at all.
