Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.10.24+
Many Thanks! This is my driver ,i wonna compiled it on raspbian wheezy 0925with kernel 3.6.11+
https://www.dropbox.com/s/zvrhhvdwuahb1 ... rce.tar.gz
This driver can be compiled and used on normal raspbmc. But raspbmc too consume system resources, so I want to use this drive on raspbian. A few days ago when I used rpi-update the kernel upgrade to 3.10.22 after raspbian, compile and install the driver, the driver fails, the hardware does not work properly, so this is what I want to use this driver in 3.6.11 + kernel reasons.
I couldn't get the damn wi-fi to connect... Turns out the ssid is case sensitive DOH!!!!!
working like a dream now.
I'm trying to get it to work on my
Linux alarmpi 3.10.24-1-ARCH #1 PREEMPT Fri Dec 13 01:21:41 CST 2013 armv6l GNU/Linux
Everything works find until I enter:
sudo insmod /lib/modules/3.10.24-1-ARCH/kernel/drivers/net/wireless/8188eu.ko
I get:
insmod: ERROR: could not insert module /lib/modules/3.10.24-1-ARCH/kernel/drivers/net/wireless/8188eu.ko: Invalid module format
Any ideas please?
I get:
Any ideas please?
Yes, you need the driver compiled for ARCH. The drivers I compile are for Raspbian and will not work with Arch or any other version for that matter.albertschulz wrote:I'm trying to get it to work on my
I get:
Any ideas please?
MrEngman
Hi there, MrEngman,
first off, thanks for the great jobs on the driver and crystal-clear setup instructions, made my day !
hopefully you'll appreciate the script below: it is a "download and install" script which I devised to automate the setup procedure you provide in the first post. The script is intended to run "as is" on most distribs and should be easy to maintain for upcoming upgrades. Works by selecting the proper tarball based on matching the target host uname with the specs in the comments header, then downloads and installs the driver and firmware, and checks that the kernel module was successfully loaded. Probably needs a bit more testing and improvements, but worked for me. Cheers.
#!/bin/bash
set -e
# 3.6.11+ #371 up to #520 inclusive - 8188eu-20130209.tar.gz
# 3.6.11+ #524, #528, #532 - 8188eu-20130815.tar.gz
# 3.6.11+ #538, #541, #545, #551, #557 - 8188eu-20130830.tar.gz
# 3.10.18+ #577 - 8188eu-20131105.tar.gz
# 3.10.18+ #579, #585 - 8188eu-20131106.tar.gz
# 3.10.18+ #587 - 8188eu-20131110.tar.gz
# 3.10.18+ #590, #592 - 8188eu-20131111.tar.gz
# 3.10.18+ #594, #596 - 8188eu-20131113.tar.gz
# 3.10.19+ #600 - 8188eu-20131113.tar.gz
# 3.10.21+ #602, #604 - 8188eu-20131113.tar.gz
# 3.10.22+ #606 - 8188eu-20131206.tar.gz
# 3.10.23+ #608 - 8188eu-20131209.tar.gz
# 3.10.24+ #610 - 8188eu-20131209.tar.gz
kernel=$(uname -r)
build=$(uname -v | awk '{print $1}' | tr -d '#')
mileage="#$build"
if [ $kernel = "3.6.11+" ] && [ $build -gt 370 ] && [ $build -lt 521 ] ; then
tarfile=8188eu-20130209.tar.gz
else
tarfile=$(cat "$0" | grep $kernel | grep $mileage | awk '{print $NF}')
fi
if [ ! "$tarfile" ] ; then
echo "error: cannot match kernel: $kernel $mileage"
echo "check for updates at www.raspberrypi.org:"
echo "http://www.raspberrypi.org/phpBB3/viewtopic.php?p=462982"
echo "or select closest compatible version"
exit 1
fi
echo "downloading $tarfile"
tmpdir=$(mktemp -d)
cd $tmpdir
curl -s https://dl.dropboxusercontent.com/u/80256631/$tarfile | tar xz
if [ -f README ] ; then
echo "please check README for install notes"
echo "[press any key to proceed]"
read -s -n 1
less README
echo "current firmware file:"
ls -l /lib/firmware/rtlwifi/rtl8188eufw.bin
cmd="sudo cp rtl8188eufw.bin /lib/firmware/rtlwifi"
echo "about to execute: $cmd"
echo "[press 'y' to proceed, any other key to skip]"
read -s -n 1 ans
[ "$ans" = "y" ] && echo "installing new firmware" && $cmd
fi
echo "installing kernel module"
sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
lsmod | grep -q 8188eu || echo "error: module not loaded"
\rm -rf $tmpdir
Yes, it does helpPiney wrote:I couldn't get the damn wi-fi to connect... Turns out the ssid is case sensitive DOH!!!!!
MrEngman
Interesting. Looks like you understand scripting rather better than I do. I did something like that to install the rtl8188cus driver before it was included in Linux images for the Pi. You might be interested to see it. You will find it here.LaFambe wrote:Hi there, MrEngman,
#!/bin/bash set -e # 3.6.11+ #371 up to #520 inclusive - 8188eu-20130209.tar.gz # 3.6.11+ #524, #528, #532 - 8188eu-20130815.tar.gz # 3.6.11+ #538, #541, #545, #551, #557 - 8188eu-20130830.tar.gz # 3.10.18+ #577 - 8188eu-20131105.tar.gz # 3.10.18+ #579, #585 - 8188eu-20131106.tar.gz # 3.10.18+ #587 - 8188eu-20131110.tar.gz # 3.10.18+ #590, #592 - 8188eu-20131111.tar.gz # 3.10.18+ #594, #596 - 8188eu-20131113.tar.gz # 3.10.19+ #600 - 8188eu-20131113.tar.gz # 3.10.21+ #602, #604 - 8188eu-20131113.tar.gz # 3.10.22+ #606 - 8188eu-20131206.tar.gz # 3.10.23+ #608 - 8188eu-20131209.tar.gz # 3.10.24+ #610 - 8188eu-20131209.tar.gz kernel=$(uname -r) build=$(uname -v | awk '{print $1}' | tr -d '#') mileage="#$build" if [ $kernel = "3.6.11+" ] && [ $build -gt 370 ] && [ $build -lt 521 ] ; then tarfile=8188eu-20130209.tar.gz else tarfile=$(cat "$0" | grep $kernel | grep $mileage | awk '{print $NF}') fi if [ ! "$tarfile" ] ; then echo "error: cannot match kernel: $kernel $mileage" echo "check for updates at www.raspberrypi.org:" echo "http://www.raspberrypi.org/phpBB3/viewtopic.php?p=462982" echo "or select closest compatible version" exit 1 fi echo "downloading $tarfile" tmpdir=$(mktemp -d) cd $tmpdir curl -s https://dl.dropboxusercontent.com/u/80256631/$tarfile | tar xz if [ -f README ] ; then echo "please check README for install notes" echo "[press any key to proceed]" read -s -n 1 less README echo "current firmware file:" ls -l /lib/firmware/rtlwifi/rtl8188eufw.bin cmd="sudo cp rtl8188eufw.bin /lib/firmware/rtlwifi" echo "about to execute: $cmd" echo "[press 'y' to proceed, any other key to skip]" read -s -n 1 ans [ "$ans" = "y" ] && echo "installing new firmware" && $cmd fi echo "installing kernel module" sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko sudo depmod -a lsmod | grep -q 8188eu || echo "error: module not loaded" \rm -rf $tmpdir
MrEngman
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.10.23+
This is my dmesg. Something is really wrong, it keeps repeating R8188EU: ERROR indicate disassoc, but I don't know what this means. I didn't install anything special, just some python libraries.bob1122 wrote:Please post dmesg [run dmesg from bash]martinahoj wrote:I hate to say it, but I'm having a weird problem with last few versions (3.10.23, 3.10.22, 3.10.20). For some reason it keeps connectiong and disconnection every cca 20s and I'm sure with clean Raspberian Wheezy it worked fine. I'm using wicd network manager. This is what it looks like when I ping my RPi.Do you have any idea what's wrong? I had to upgrade to more recent kernel because I need newer version of raspistill.Code: Select all
64 bytes from 192.168.0.107: icmp_seq=0 ttl=64 time=109.983 ms 64 bytes from 192.168.0.107: icmp_seq=1 ttl=64 time=19.629 ms 64 bytes from 192.168.0.107: icmp_seq=2 ttl=64 time=8.761 ms 64 bytes from 192.168.0.107: icmp_seq=3 ttl=64 time=14.978 ms 64 bytes from 192.168.0.107: icmp_seq=4 ttl=64 time=2.832 ms 64 bytes from 192.168.0.107: icmp_seq=5 ttl=64 time=4.754 ms 64 bytes from 192.168.0.107: icmp_seq=6 ttl=64 time=48.291 ms 64 bytes from 192.168.0.107: icmp_seq=7 ttl=64 time=12.713 ms 64 bytes from 192.168.0.107: icmp_seq=8 ttl=64 time=6.062 ms 64 bytes from 192.168.0.107: icmp_seq=9 ttl=64 time=2.636 ms 64 bytes from 192.168.0.107: icmp_seq=10 ttl=64 time=9.447 ms 64 bytes from 192.168.0.107: icmp_seq=11 ttl=64 time=2.920 ms Request timeout for icmp_seq 12 Request timeout for icmp_seq 13 Request timeout for icmp_seq 14 Request timeout for icmp_seq 15 Request timeout for icmp_seq 16 Request timeout for icmp_seq 17 Request timeout for icmp_seq 18 Request timeout for icmp_seq 19 Request timeout for icmp_seq 20 Request timeout for icmp_seq 21 Request timeout for icmp_seq 22 Request timeout for icmp_seq 23 Request timeout for icmp_seq 24 Request timeout for icmp_seq 25 Request timeout for icmp_seq 26 Request timeout for icmp_seq 27 Request timeout for icmp_seq 28 Request timeout for icmp_seq 29 Request timeout for icmp_seq 30 Request timeout for icmp_seq 31 Request timeout for icmp_seq 32 Request timeout for icmp_seq 33 Request timeout for icmp_seq 34 Request timeout for icmp_seq 35 Request timeout for icmp_seq 36 Request timeout for icmp_seq 37 Request timeout for icmp_seq 38 Request timeout for icmp_seq 39 Request timeout for icmp_seq 40 Request timeout for icmp_seq 41 64 bytes from 192.168.0.107: icmp_seq=42 ttl=64 time=107.040 ms 64 bytes from 192.168.0.107: icmp_seq=43 ttl=64 time=48.828 ms 64 bytes from 192.168.0.107: icmp_seq=44 ttl=64 time=5.504 ms 64 bytes from 192.168.0.107: icmp_seq=45 ttl=64 time=7.116 ms 64 bytes from 192.168.0.107: icmp_seq=46 ttl=64 time=6.706 ms 64 bytes from 192.168.0.107: icmp_seq=47 ttl=64 time=4.426 ms 64 bytes from 192.168.0.107: icmp_seq=48 ttl=64 time=5.399 ms 64 bytes from 192.168.0.107: icmp_seq=49 ttl=64 time=6.073 ms 64 bytes from 192.168.0.107: icmp_seq=50 ttl=64 time=25.729 ms 64 bytes from 192.168.0.107: icmp_seq=51 ttl=64 time=6.100 ms 64 bytes from 192.168.0.107: icmp_seq=52 ttl=64 time=6.255 ms 64 bytes from 192.168.0.107: icmp_seq=53 ttl=64 time=6.347 ms 64 bytes from 192.168.0.107: icmp_seq=54 ttl=64 time=9.725 ms 64 bytes from 192.168.0.107: icmp_seq=55 ttl=64 time=6.231 ms 64 bytes from 192.168.0.107: icmp_seq=56 ttl=64 time=16.880 ms 64 bytes from 192.168.0.107: icmp_seq=57 ttl=64 time=5.697 ms 64 bytes from 192.168.0.107: icmp_seq=58 ttl=64 time=7.097 ms 64 bytes from 192.168.0.107: icmp_seq=59 ttl=64 time=5.562 ms Request timeout for icmp_seq 60 Request timeout for icmp_seq 61 Request timeout for icmp_seq 62 Request timeout for icmp_seq 63 Request timeout for icmp_seq 64 Request timeout for icmp_seq 65 Request timeout for icmp_seq 66 Request timeout for icmp_seq 67 Request timeout for icmp_seq 68 Request timeout for icmp_seq 69 Request timeout for icmp_seq 70 Request timeout for icmp_seq 71 Request timeout for icmp_seq 72 Request timeout for icmp_seq 73 Request timeout for icmp_seq 74 Request timeout for icmp_seq 75 Request timeout for icmp_seq 76 Request timeout for icmp_seq 77 Request timeout for icmp_seq 78 Request timeout for icmp_seq 79 Request timeout for icmp_seq 80 Request timeout for icmp_seq 81 Request timeout for icmp_seq 82 Request timeout for icmp_seq 83 Request timeout for icmp_seq 84 Request timeout for icmp_seq 85 Request timeout for icmp_seq 86 Request timeout for icmp_seq 87 Request timeout for icmp_seq 88 Request timeout for icmp_seq 89 Request timeout for icmp_seq 90 Request timeout for icmp_seq 91 Request timeout for icmp_seq 92 Request timeout for icmp_seq 93 Request timeout for icmp_seq 94 Request timeout for icmp_seq 95 Request timeout for icmp_seq 96 Request timeout for icmp_seq 97 Request timeout for icmp_seq 98 Request timeout for icmp_seq 99 Request timeout for icmp_seq 100 64 bytes from 192.168.0.107: icmp_seq=101 ttl=64 time=73.622 ms 64 bytes from 192.168.0.107: icmp_seq=102 ttl=64 time=52.785 ms 64 bytes from 192.168.0.107: icmp_seq=103 ttl=64 time=5.372 ms 64 bytes from 192.168.0.107: icmp_seq=104 ttl=64 time=6.572 ms 64 bytes from 192.168.0.107: icmp_seq=105 ttl=64 time=2.741 ms 64 bytes from 192.168.0.107: icmp_seq=106 ttl=64 time=5.399 ms 64 bytes from 192.168.0.107: icmp_seq=107 ttl=64 time=5.389 ms 64 bytes from 192.168.0.107: icmp_seq=108 ttl=64 time=2.680 ms 64 bytes from 192.168.0.107: icmp_seq=109 ttl=64 time=6.017 ms 64 bytes from 192.168.0.107: icmp_seq=110 ttl=64 time=21.945 ms 64 bytes from 192.168.0.107: icmp_seq=111 ttl=64 time=6.081 ms 64 bytes from 192.168.0.107: icmp_seq=112 ttl=64 time=6.321 ms 64 bytes from 192.168.0.107: icmp_seq=113 ttl=64 time=5.503 ms 64 bytes from 192.168.0.107: icmp_seq=114 ttl=64 time=3.377 ms 64 bytes from 192.168.0.107: icmp_seq=115 ttl=64 time=6.648 ms 64 bytes from 192.168.0.107: icmp_seq=116 ttl=64 time=6.187 ms 64 bytes from 192.168.0.107: icmp_seq=117 ttl=64 time=6.238 ms 64 bytes from 192.168.0.107: icmp_seq=118 ttl=64 time=3.833 ms 64 bytes from 192.168.0.107: icmp_seq=119 ttl=64 time=15.038 ms Request timeout for icmp_seq 120 Request timeout for icmp_seq 121 Request timeout for icmp_seq 122 Request timeout for icmp_seq 123 Request timeout for icmp_seq 124 Request timeout for icmp_seq 125 Request timeout for icmp_seq 126 Request timeout for icmp_seq 127 Request timeout for icmp_seq 128 Request timeout for icmp_seq 129 Request timeout for icmp_seq 130 Request timeout for icmp_seq 131 Request timeout for icmp_seq 132 Request timeout for icmp_seq 133 Request timeout for icmp_seq 134 Request timeout for icmp_seq 135 Request timeout for icmp_seq 136 Request timeout for icmp_seq 137 Request timeout for icmp_seq 138 Request timeout for icmp_seq 139 Request timeout for icmp_seq 140
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.23+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #608 PREEMPT Mon Dec 9 21:11:23 GMT 2013
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 16 MiB at 17000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 98304
[ 0.000000] free_area_init_node: node 0, pgdat c05d1a4c, node_mem_map c067e000
[ 0.000000] Normal zone: 768 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 98304 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97536
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708.boardrev=0xf bcm2708.serial=0x554fb391 smsc95xx.macaddr=B8:27:EB:4F:B3:91 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 384MB = 384MB total
[ 0.000000] Memory: 366624k/366624k available, 26592k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd8800000 - 0xff000000 ( 616 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd8000000 ( 384 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05737e0 (5550 kB)
[ 0.000000] .init : 0xc0574000 - 0xc0598224 ( 145 kB)
[ 0.000000] .data : 0xc059a000 - 0xc05d2550 ( 226 kB)
[ 0.000000] .bss : 0xc05d2550 - 0xc067d0c0 ( 683 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001151] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001214] pid_max: default: 32768 minimum: 301
[ 0.001677] Mount-cache hash table entries: 512
[ 0.002478] Initializing cgroup subsys devices
[ 0.002539] Initializing cgroup subsys freezer
[ 0.002573] Initializing cgroup subsys blkio
[ 0.002721] CPU: Testing write buffer coherency: ok
[ 0.003166] Setting up static identity map for 0xc0405bc8 - 0xc0405c24
[ 0.004947] devtmpfs: initialized
[ 0.019264] NET: Registered protocol family 16
[ 0.025187] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.026279] bcm2708.uart_clock = 0
[ 0.027960] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.028014] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.028050] mailbox: Broadcom VideoCore Mailbox driver
[ 0.028144] bcm2708_vcio: mailbox at f200b880
[ 0.028245] bcm_power: Broadcom power driver
[ 0.028283] bcm_power_open() -> 0
[ 0.028308] bcm_power_request(0, 8)
[ 0.529023] bcm_mailbox_read -> 00000080, 0
[ 0.529067] bcm_power_request -> 0
[ 0.529289] Serial: AMBA PL011 UART driver
[ 0.529450] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.867136] console [ttyAMA0] enabled
[ 0.893148] bio: create slab <bio-0> at 0
[ 0.898445] SCSI subsystem initialized
[ 0.902538] usbcore: registered new interface driver usbfs
[ 0.908255] usbcore: registered new interface driver hub
[ 0.913815] usbcore: registered new device driver usb
[ 0.920367] Switching to clocksource stc
[ 0.924701] FS-Cache: Loaded
[ 0.927881] CacheFiles: Loaded
[ 0.943654] NET: Registered protocol family 2
[ 0.949053] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.956315] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.962838] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.969309] TCP: reno registered
[ 0.972566] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.978472] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.985211] NET: Registered protocol family 1
[ 0.990128] RPC: Registered named UNIX socket transport module.
[ 0.996186] RPC: Registered udp transport module.
[ 1.000910] RPC: Registered tcp transport module.
[ 1.005661] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.013024] bcm2708_dma: DMA manager at f2007000
[ 1.017841] bcm2708_gpio: bcm2708_gpio_probe c05a7db0
[ 1.023312] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.032643] audit: initializing netlink socket (disabled)
[ 1.038316] type=2000 audit(0.880:1): initialized
[ 1.200134] VFS: Disk quotas dquot_6.5.2
[ 1.204536] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.213310] FS-Cache: Netfs 'nfs' registered for caching
[ 1.220046] NFS: Registering the id_resolver key type
[ 1.225320] Key type id_resolver registered
[ 1.229526] Key type id_legacy registered
[ 1.234249] msgmni has been set to 748
[ 1.240143] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.247987] io scheduler noop registered
[ 1.251947] io scheduler deadline registered (default)
[ 1.257555] io scheduler cfq registered
[ 1.262799] BCM2708FB: allocated DMA memory 57400000
[ 1.267931] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.287864] Console: switching to colour frame buffer device 80x30
[ 1.298466] uart-pl011 dev:f1: no DMA platform data
[ 1.305095] kgdb: Registered I/O driver kgdboc.
[ 1.311916] vc-cma: Videocore CMA driver
[ 1.317534] vc-cma: vc_cma_base = 0x00000000
[ 1.323792] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.330803] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.346906] brd: module loaded
[ 1.356683] loop: module loaded
[ 1.361564] vchiq: vchiq_init_state: slot_zero = 0xd7000000, is_master = 0
[ 1.370942] Loading iSCSI transport class v2.0-870.
[ 1.378562] usbcore: registered new interface driver ax88179_178a
[ 1.386721] usbcore: registered new interface driver smsc95xx
[ 1.394006] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.601354] Core Release: 2.80a
[ 1.606040] Setting default values for core params
[ 1.612299] Finished setting default values for core params
[ 1.819392] Using Buffer DMA mode
[ 1.824156] Periodic Transfer Interrupt Enhancement - disabled
[ 1.831427] Multiprocessor Interrupt Enhancement - disabled
[ 1.838463] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.844244] Dedicated Tx FIFOs mode
[ 1.849745] dwc_otg: Microframe scheduler enabled
[ 1.849980] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.856502] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.866777] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.873793] Init: Port Power? op_state=1
[ 1.879229] Init: Power Port (0)
[ 1.884041] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.892426] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.902755] usb usb1: Product: DWC OTG Controller
[ 1.909099] usb usb1: Manufacturer: Linux 3.10.23+ dwc_otg_hcd
[ 1.916600] usb usb1: SerialNumber: bcm2708_usb
[ 1.923501] hub 1-0:1.0: USB hub found
[ 1.928966] hub 1-0:1.0: 1 port detected
[ 1.934882] dwc_otg: FIQ enabled
[ 1.934901] dwc_otg: NAK holdoff enabled
[ 1.934910] dwc_otg: FIQ split fix enabled
[ 1.934929] Module dwc_common_port init
[ 1.935358] usbcore: registered new interface driver usb-storage
[ 1.943396] mousedev: PS/2 mouse device common for all mice
[ 1.950867] usbcore: registered new interface driver xpad
[ 1.958588] bcm2835-cpufreq: min=700000 max=900000 cur=700000
[ 1.966118] bcm2835-cpufreq: switching to governor powersave
[ 1.973361] bcm2835-cpufreq: switching to governor powersave
[ 1.980581] cpuidle: using governor ladder
[ 1.986242] cpuidle: using governor menu
[ 1.991691] sdhci: Secure Digital Host Controller Interface driver
[ 1.999394] sdhci: Copyright(c) Pierre Ossman
[ 2.005340] sdhci: Enable low-latency mode
[ 2.054416] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.065494] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.072951] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.080331] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.090229] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.104804] usbcore: registered new interface driver usbhid
[ 2.112066] usbhid: USB HID core driver
[ 2.122131] TCP: cubic registered
[ 2.129110] Initializing XFRM netlink socket
[ 2.137084] Indeed it is in host mode hprt0 = 00021501
[ 2.144495] NET: Registered protocol family 17
[ 2.167635] Key type dns_resolver registered
[ 2.174074] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.195228] registered taskstats version 1
[ 2.211826] mmc0: new high speed SDHC card at address 1234
[ 2.224425] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 2.245068] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[ 2.253210] mmcblk0: p1 p2
[ 2.384453] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.394046] Indeed it is in host mode hprt0 = 00001101
[ 2.595108] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.603678] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.613705] hub 1-1:1.0: USB hub found
[ 2.619607] hub 1-1:1.0: 3 ports detected
[ 2.904607] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.025147] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.033748] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.047297] smsc95xx v1.0.4
[ 3.112978] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4f:b3:91
[ 3.204645] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.325687] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0201
[ 3.334444] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.345308] usb 1-1.2: Product: USB 2.0 Hub [MTT]
[ 3.352794] hub 1-1.2:1.0: USB hub found
[ 3.358826] hub 1-1.2:1.0: 7 ports detected
[ 3.644598] usb 1-1.2.5: new high-speed USB device number 5 using dwc_otg
[ 3.746111] usb 1-1.2.5: New USB device found, idVendor=0bda, idProduct=8179
[ 3.755006] usb 1-1.2.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.765865] usb 1-1.2.5: Product: 802.11n NIC
[ 3.771919] usb 1-1.2.5: Manufacturer: Realtek
[ 3.778053] usb 1-1.2.5: SerialNumber: 00E04C0001
[ 16.644800] EXT4-fs (mmcblk0p2): recovery complete
[ 16.655515] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 16.667095] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 16.677066] devtmpfs: mounted
[ 16.682227] Freeing unused kernel memory: 144K (c0574000 - c0598000)
[ 18.237987] udevd[156]: starting version 175
[ 20.075404] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_A_CUT_1T1R_RomVer(0)
[ 20.201176] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory
[ 20.616277] usbcore: registered new interface driver r8188eu
[ 22.654693] usb 1-1.2.4: new high-speed USB device number 6 using dwc_otg
[ 22.794094] usb 1-1.2.4: New USB device found, idVendor=05ac, idProduct=1006
[ 22.817859] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 22.854541] usb 1-1.2.4: Product: Keyboard Hub
[ 22.860983] usb 1-1.2.4: Manufacturer: Apple, Inc.
[ 22.880274] usb 1-1.2.4: SerialNumber: 000000000000
[ 22.905999] hub 1-1.2.4:1.0: USB hub found
[ 22.924620] hub 1-1.2.4:1.0: 3 ports detected
[ 23.224870] usb 1-1.2.4.2: new low-speed USB device number 7 using dwc_otg
[ 23.349740] usb 1-1.2.4.2: New USB device found, idVendor=05ac, idProduct=0250
[ 23.370242] usb 1-1.2.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 23.394504] usb 1-1.2.4.2: Product: Apple Keyboard
[ 23.417996] usb 1-1.2.4.2: Manufacturer: Apple Inc.
[ 23.654616] input: Apple Inc. Apple Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4.2/1-1.2.4.2:1.0/input/input0
[ 23.735570] apple 0003:05AC:0250.0001: input,hidraw0: USB HID v1.11 Keyboard [Apple Inc. Apple Keyboard] on usb-bcm2708_usb-1.2.4.2/input0
[ 23.830542] input: Apple Inc. Apple Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4.2/1-1.2.4.2:1.1/input/input1
[ 23.996073] apple 0003:05AC:0250.0002: input,hidraw1: USB HID v1.11 Device [Apple Inc. Apple Keyboard] on usb-bcm2708_usb-1.2.4.2/input1
[ 33.235530] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 34.597585] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 40.467729] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 43.060081] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 43.252471] R8188EU: Firmware Version 11, SubVersion 1, Signature 0x88e1
[ 43.805543] MAC Address = 64:66:b3:0e:83:70
[ 47.527075] bcm2835-cpufreq: switching to governor ondemand
[ 47.527106] bcm2835-cpufreq: switching to governor ondemand
[ 49.768549] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 73.108551] R8188EU: ERROR indicate disassoc
[ 73.367836] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 73.451611] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 73.684498] R8188EU: ERROR indicate disassoc
[ 78.048686] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38
[ 78.054307] R8188EU: ERROR indicate disassoc
[ 79.478234] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38
[ 79.484207] R8188EU: ERROR indicate disassoc
[ 85.003055] R8188EU: ERROR assoc success
[ 121.785782] R8188EU: ERROR indicate disassoc
[ 121.953691] R8188EU: ERROR indicate disassoc
[ 122.620758] R8188EU: ERROR indicate disassoc
[ 123.030434] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 123.118499] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 126.082856] R8188EU: ERROR indicate disassoc
[ 130.347279] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 130.434752] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 140.943386] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38
[ 140.949947] R8188EU: ERROR indicate disassoc
[ 142.372695] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38
[ 142.379852] R8188EU: ERROR indicate disassoc
[ 147.895701] R8188EU: ERROR assoc success
[ 183.780333] R8188EU: ERROR indicate disassoc
[ 183.961114] R8188EU: ERROR indicate disassoc
[ 184.648308] R8188EU: ERROR indicate disassoc
[ 185.073064] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 185.164172] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 188.209042] R8188EU: ERROR indicate disassoc
[ 188.604949] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 188.693905] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 188.906777] R8188EU: ERROR indicate disassoc
[ 193.202025] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38
[ 193.206334] R8188EU: ERROR indicate disassoc
[ 194.635675] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38
[ 194.636289] R8188EU: ERROR indicate disassoc
[ 200.051146] R8188EU: ERROR assoc success
[ 231.839862] R8188EU: ERROR indicate disassoc
[ 232.017529] R8188EU: ERROR indicate disassoc
[ 235.251754] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 235.337351] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 238.794292] R8188EU: ERROR indicate disassoc
[ 239.191765] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 239.280400] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 239.494263] R8188EU: ERROR indicate disassoc
[ 243.718412] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38
[ 243.722838] R8188EU: ERROR indicate disassoc
[ 245.149993] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38
[ 245.152799] R8188EU: ERROR indicate disassoc
[ 250.673816] R8188EU: ERROR assoc success
[ 251.047754] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
ERROR sta recv deauth reason code(11) ismartinahoj wrote:This is my dmesg. Something is really wrong, it keeps repeating R8188EU: ERROR indicate disassoc, but I don't know what this means. I didn't install anything special, just some python libraries.bob1122 wrote:Please post dmesg [run dmesg from bash]martinahoj wrote:I hate to say it, but I'm having a weird problem with last few versions (3.10.23, 3.10.22, 3.10.20). For some reason it keeps connectiong and disconnection every cca 20s and I'm sure with clean Raspberian Wheezy it worked fine. I'm using wicd network manager. This is what it looks like when I ping my RPi.Do you have any idea what's wrong? I had to upgrade to more recent kernel because I need newer version of raspistill.Code: Select all
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.23+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #608 PREEMPT Mon Dec 9 21:11:23 GMT 2013 [ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache [ 0.000000] Machine: BCM2708 [ 0.000000] cma: CMA: reserved 16 MiB at 17000000 [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] On node 0 totalpages: 98304 [ 0.000000] free_area_init_node: node 0, pgdat c05d1a4c, node_mem_map c067e000 [ 0.000000] Normal zone: 768 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 98304 pages, LIFO batch:31 [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97536 [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708.boardrev=0xf bcm2708.serial=0x554fb391 smsc95xx.macaddr=B8:27:EB:4F:B3:91 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 384MB = 384MB total [ 0.000000] Memory: 366624k/366624k available, 26592k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xd8800000 - 0xff000000 ( 616 MB) [ 0.000000] lowmem : 0xc0000000 - 0xd8000000 ( 384 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .text : 0xc0008000 - 0xc05737e0 (5550 kB) [ 0.000000] .init : 0xc0574000 - 0xc0598224 ( 145 kB) [ 0.000000] .data : 0xc059a000 - 0xc05d2550 ( 226 kB) [ 0.000000] .bss : 0xc05d2550 - 0xc067d0c0 ( 683 kB) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:330 [ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms [ 0.000000] Switching to timer-based delay loop [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.001151] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.001214] pid_max: default: 32768 minimum: 301 [ 0.001677] Mount-cache hash table entries: 512 [ 0.002478] Initializing cgroup subsys devices [ 0.002539] Initializing cgroup subsys freezer [ 0.002573] Initializing cgroup subsys blkio [ 0.002721] CPU: Testing write buffer coherency: ok [ 0.003166] Setting up static identity map for 0xc0405bc8 - 0xc0405c24 [ 0.004947] devtmpfs: initialized [ 0.019264] NET: Registered protocol family 16 [ 0.025187] DMA: preallocated 4096 KiB pool for atomic coherent allocations [ 0.026279] bcm2708.uart_clock = 0 [ 0.027960] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. [ 0.028014] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.028050] mailbox: Broadcom VideoCore Mailbox driver [ 0.028144] bcm2708_vcio: mailbox at f200b880 [ 0.028245] bcm_power: Broadcom power driver [ 0.028283] bcm_power_open() -> 0 [ 0.028308] bcm_power_request(0, 8) [ 0.529023] bcm_mailbox_read -> 00000080, 0 [ 0.529067] bcm_power_request -> 0 [ 0.529289] Serial: AMBA PL011 UART driver [ 0.529450] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3 [ 0.867136] console [ttyAMA0] enabled [ 0.893148] bio: create slab <bio-0> at 0 [ 0.898445] SCSI subsystem initialized [ 0.902538] usbcore: registered new interface driver usbfs [ 0.908255] usbcore: registered new interface driver hub [ 0.913815] usbcore: registered new device driver usb [ 0.920367] Switching to clocksource stc [ 0.924701] FS-Cache: Loaded [ 0.927881] CacheFiles: Loaded [ 0.943654] NET: Registered protocol family 2 [ 0.949053] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.956315] TCP bind hash table entries: 4096 (order: 2, 16384 bytes) [ 0.962838] TCP: Hash tables configured (established 4096 bind 4096) [ 0.969309] TCP: reno registered [ 0.972566] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.978472] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.985211] NET: Registered protocol family 1 [ 0.990128] RPC: Registered named UNIX socket transport module. [ 0.996186] RPC: Registered udp transport module. [ 1.000910] RPC: Registered tcp transport module. [ 1.005661] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.013024] bcm2708_dma: DMA manager at f2007000 [ 1.017841] bcm2708_gpio: bcm2708_gpio_probe c05a7db0 [ 1.023312] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB) [ 1.032643] audit: initializing netlink socket (disabled) [ 1.038316] type=2000 audit(0.880:1): initialized [ 1.200134] VFS: Disk quotas dquot_6.5.2 [ 1.204536] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.213310] FS-Cache: Netfs 'nfs' registered for caching [ 1.220046] NFS: Registering the id_resolver key type [ 1.225320] Key type id_resolver registered [ 1.229526] Key type id_legacy registered [ 1.234249] msgmni has been set to 748 [ 1.240143] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) [ 1.247987] io scheduler noop registered [ 1.251947] io scheduler deadline registered (default) [ 1.257555] io scheduler cfq registered [ 1.262799] BCM2708FB: allocated DMA memory 57400000 [ 1.267931] BCM2708FB: allocated DMA channel 0 @ f2007000 [ 1.287864] Console: switching to colour frame buffer device 80x30 [ 1.298466] uart-pl011 dev:f1: no DMA platform data [ 1.305095] kgdb: Registered I/O driver kgdboc. [ 1.311916] vc-cma: Videocore CMA driver [ 1.317534] vc-cma: vc_cma_base = 0x00000000 [ 1.323792] vc-cma: vc_cma_size = 0x00000000 (0 MiB) [ 1.330803] vc-cma: vc_cma_initial = 0x00000000 (0 MiB) [ 1.346906] brd: module loaded [ 1.356683] loop: module loaded [ 1.361564] vchiq: vchiq_init_state: slot_zero = 0xd7000000, is_master = 0 [ 1.370942] Loading iSCSI transport class v2.0-870. [ 1.378562] usbcore: registered new interface driver ax88179_178a [ 1.386721] usbcore: registered new interface driver smsc95xx [ 1.394006] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 1.601354] Core Release: 2.80a [ 1.606040] Setting default values for core params [ 1.612299] Finished setting default values for core params [ 1.819392] Using Buffer DMA mode [ 1.824156] Periodic Transfer Interrupt Enhancement - disabled [ 1.831427] Multiprocessor Interrupt Enhancement - disabled [ 1.838463] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.844244] Dedicated Tx FIFOs mode [ 1.849745] dwc_otg: Microframe scheduler enabled [ 1.849980] dwc_otg bcm2708_usb: DWC OTG Controller [ 1.856502] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1 [ 1.866777] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000 [ 1.873793] Init: Port Power? op_state=1 [ 1.879229] Init: Power Port (0) [ 1.884041] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.892426] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.902755] usb usb1: Product: DWC OTG Controller [ 1.909099] usb usb1: Manufacturer: Linux 3.10.23+ dwc_otg_hcd [ 1.916600] usb usb1: SerialNumber: bcm2708_usb [ 1.923501] hub 1-0:1.0: USB hub found [ 1.928966] hub 1-0:1.0: 1 port detected [ 1.934882] dwc_otg: FIQ enabled [ 1.934901] dwc_otg: NAK holdoff enabled [ 1.934910] dwc_otg: FIQ split fix enabled [ 1.934929] Module dwc_common_port init [ 1.935358] usbcore: registered new interface driver usb-storage [ 1.943396] mousedev: PS/2 mouse device common for all mice [ 1.950867] usbcore: registered new interface driver xpad [ 1.958588] bcm2835-cpufreq: min=700000 max=900000 cur=700000 [ 1.966118] bcm2835-cpufreq: switching to governor powersave [ 1.973361] bcm2835-cpufreq: switching to governor powersave [ 1.980581] cpuidle: using governor ladder [ 1.986242] cpuidle: using governor menu [ 1.991691] sdhci: Secure Digital Host Controller Interface driver [ 1.999394] sdhci: Copyright(c) Pierre Ossman [ 2.005340] sdhci: Enable low-latency mode [ 2.054416] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA [ 2.065494] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77 [ 2.072951] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.080331] ledtrig-cpu: registered to indicate activity on CPUs [ 2.090229] hidraw: raw HID events driver (C) Jiri Kosina [ 2.104804] usbcore: registered new interface driver usbhid [ 2.112066] usbhid: USB HID core driver [ 2.122131] TCP: cubic registered [ 2.129110] Initializing XFRM netlink socket [ 2.137084] Indeed it is in host mode hprt0 = 00021501 [ 2.144495] NET: Registered protocol family 17 [ 2.167635] Key type dns_resolver registered [ 2.174074] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5 [ 2.195228] registered taskstats version 1 [ 2.211826] mmc0: new high speed SDHC card at address 1234 [ 2.224425] drivers/rtc/hctosys.c: unable to open rtc device (rtc0) [ 2.245068] mmcblk0: mmc0:1234 SA04G 3.63 GiB [ 2.253210] mmcblk0: p1 p2 [ 2.384453] usb 1-1: new high-speed USB device number 2 using dwc_otg [ 2.394046] Indeed it is in host mode hprt0 = 00001101 [ 2.595108] usb 1-1: New USB device found, idVendor=0424, idProduct=9512 [ 2.603678] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 2.613705] hub 1-1:1.0: USB hub found [ 2.619607] hub 1-1:1.0: 3 ports detected [ 2.904607] usb 1-1.1: new high-speed USB device number 3 using dwc_otg [ 3.025147] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00 [ 3.033748] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 3.047297] smsc95xx v1.0.4 [ 3.112978] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4f:b3:91 [ 3.204645] usb 1-1.2: new high-speed USB device number 4 using dwc_otg [ 3.325687] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0201 [ 3.334444] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 3.345308] usb 1-1.2: Product: USB 2.0 Hub [MTT] [ 3.352794] hub 1-1.2:1.0: USB hub found [ 3.358826] hub 1-1.2:1.0: 7 ports detected [ 3.644598] usb 1-1.2.5: new high-speed USB device number 5 using dwc_otg [ 3.746111] usb 1-1.2.5: New USB device found, idVendor=0bda, idProduct=8179 [ 3.755006] usb 1-1.2.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3.765865] usb 1-1.2.5: Product: 802.11n NIC [ 3.771919] usb 1-1.2.5: Manufacturer: Realtek [ 3.778053] usb 1-1.2.5: SerialNumber: 00E04C0001 [ 16.644800] EXT4-fs (mmcblk0p2): recovery complete [ 16.655515] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 16.667095] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 16.677066] devtmpfs: mounted [ 16.682227] Freeing unused kernel memory: 144K (c0574000 - c0598000) [ 18.237987] udevd[156]: starting version 175 [ 20.075404] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_A_CUT_1T1R_RomVer(0) [ 20.201176] bcm2708-i2s bcm2708-i2s.0: Failed to create debugfs directory [ 20.616277] usbcore: registered new interface driver r8188eu [ 22.654693] usb 1-1.2.4: new high-speed USB device number 6 using dwc_otg [ 22.794094] usb 1-1.2.4: New USB device found, idVendor=05ac, idProduct=1006 [ 22.817859] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 22.854541] usb 1-1.2.4: Product: Keyboard Hub [ 22.860983] usb 1-1.2.4: Manufacturer: Apple, Inc. [ 22.880274] usb 1-1.2.4: SerialNumber: 000000000000 [ 22.905999] hub 1-1.2.4:1.0: USB hub found [ 22.924620] hub 1-1.2.4:1.0: 3 ports detected [ 23.224870] usb 1-1.2.4.2: new low-speed USB device number 7 using dwc_otg [ 23.349740] usb 1-1.2.4.2: New USB device found, idVendor=05ac, idProduct=0250 [ 23.370242] usb 1-1.2.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 23.394504] usb 1-1.2.4.2: Product: Apple Keyboard [ 23.417996] usb 1-1.2.4.2: Manufacturer: Apple Inc. [ 23.654616] input: Apple Inc. Apple Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4.2/1-1.2.4.2:1.0/input/input0 [ 23.735570] apple 0003:05AC:0250.0001: input,hidraw0: USB HID v1.11 Keyboard [Apple Inc. Apple Keyboard] on usb-bcm2708_usb-1.2.4.2/input0 [ 23.830542] input: Apple Inc. Apple Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4.2/1-1.2.4.2:1.1/input/input1 [ 23.996073] apple 0003:05AC:0250.0002: input,hidraw1: USB HID v1.11 Device [Apple Inc. Apple Keyboard] on usb-bcm2708_usb-1.2.4.2/input1 [ 33.235530] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 34.597585] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 40.467729] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 43.060081] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 43.252471] R8188EU: Firmware Version 11, SubVersion 1, Signature 0x88e1 [ 43.805543] MAC Address = 64:66:b3:0e:83:70 [ 47.527075] bcm2835-cpufreq: switching to governor ondemand [ 47.527106] bcm2835-cpufreq: switching to governor ondemand [ 49.768549] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS [ 73.108551] R8188EU: ERROR indicate disassoc [ 73.367836] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 73.451611] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 73.684498] R8188EU: ERROR indicate disassoc [ 78.048686] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38 [ 78.054307] R8188EU: ERROR indicate disassoc [ 79.478234] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38 [ 79.484207] R8188EU: ERROR indicate disassoc [ 85.003055] R8188EU: ERROR assoc success [ 121.785782] R8188EU: ERROR indicate disassoc [ 121.953691] R8188EU: ERROR indicate disassoc [ 122.620758] R8188EU: ERROR indicate disassoc [ 123.030434] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 123.118499] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 126.082856] R8188EU: ERROR indicate disassoc [ 130.347279] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 130.434752] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 140.943386] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38 [ 140.949947] R8188EU: ERROR indicate disassoc [ 142.372695] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38 [ 142.379852] R8188EU: ERROR indicate disassoc [ 147.895701] R8188EU: ERROR assoc success [ 183.780333] R8188EU: ERROR indicate disassoc [ 183.961114] R8188EU: ERROR indicate disassoc [ 184.648308] R8188EU: ERROR indicate disassoc [ 185.073064] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 185.164172] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 188.209042] R8188EU: ERROR indicate disassoc [ 188.604949] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 188.693905] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 188.906777] R8188EU: ERROR indicate disassoc [ 193.202025] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38 [ 193.206334] R8188EU: ERROR indicate disassoc [ 194.635675] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38 [ 194.636289] R8188EU: ERROR indicate disassoc [ 200.051146] R8188EU: ERROR assoc success [ 231.839862] R8188EU: ERROR indicate disassoc [ 232.017529] R8188EU: ERROR indicate disassoc [ 235.251754] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 235.337351] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 238.794292] R8188EU: ERROR indicate disassoc [ 239.191765] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 239.280400] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup [ 239.494263] R8188EU: ERROR indicate disassoc [ 243.718412] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38 [ 243.722838] R8188EU: ERROR indicate disassoc [ 245.149993] R8188EU: ERROR sta recv deauth reason code(11) sta:64:66:b3:82:97:38 [ 245.152799] R8188EU: ERROR indicate disassoc [ 250.673816] R8188EU: ERROR assoc success [ 251.047754] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Disassociated because the information in the Supported Channels element is unacceptable
Not sure what this means but it could be that the channel list the wifi is set to use is not compatible with the list the wifi access point is using.
Command iwlist channel will usually list the channels the wifi can use. Maybe you need to check how your access point is set up regarding channels. Just a thought.
Anyone else any ideas?
MrEngman
post moved to: ping DUP! using wireless TL-WN725N v2 dongle
Its like whenever i update my kernel got updated then usb wifi dosen't work i need to come here and always need to download the new compiled driver for latest kernel version, this is so much pain. there not something like auto fix when kernel update plz do something for this issue.
Dear MrEngman,
I'd like to compile the driver by myself,
could you quickly explain howto do ?
You could take a look here.MrRight wrote:Dear MrEngman,
MrEngman
Mr. EngMan I cannot express the amount of appreciation that I am experiencing at the moment after so many hours of blood shot eye hunting for information to get this ridiculous wifi situation in the rear view mirror. Your posts have saved the day.
Now that it's working I have to move on to the next step which is getting the silly thing to keep the connection instead of dropping it and picking it back up every few seconds. Good grief!
Thanks a million times over!
And yes as the guy in Munich did, I am most definitely extending an invitation for drinks if ever you find yourself in the New York City area!
Thank you, appreciate your comments, makes all this worthwhile.mavenmaven wrote:Mr. EngMan I cannot express the amount of appreciation that I am experiencing at the moment after so many hours of blood shot eye hunting for information to get this ridiculous wifi situation in the rear view mirror. Your posts have saved the day.
As far as your current issue I've no experience of it myself. I think, however, many would suggest it may be a power supply issue especially if the wifi adaptor is plugged directly in to the Pi, although I have my adaptor plugged directly into my Pi's USB port and have no problems. I would suggest trying a more powerful supply if you have one or perhaps plugging the wifi into a hub if you have one.
MrEngman
Hello
As everybody, many thanks to MrEngman for the permanent driver updates.
With his help, I have it working perfectly in 3.10.23+.
Unfortunately, I cannot upgrade to the 3.10.24+ version.
After a dist-upgrade, the uname -a gave this:
Linux raspberry-1 3.10.24+ #614 PREEMPT Thu Dec 19 20:38:42 GMT 2013 armv6l GNU/Linux
I still saw the Realtek entry in lsusb, but the driver was not visible in lsmod anymore. Fair enough.
I restarted the driver install procedure from scratch (rm all 8188 files in /home/pi and /lib/firmware, wget 8188eu-20131209.tar.gz, tar, cp to /lib/firmware)...
Install is ok (or seems to be) but insmod gives an error (same for modprobe):
pi@raspberry-1 ~ $ sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
pi@raspberry-1 ~ $ sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
Error: could not insert module /lib/modules/3.10.24+/kernel/drivers/net/wireless/8188eu.ko: Invalid module format
sudo modprobe 8188eu
ERROR: could not insert '8188eu': Exec format error
I did the rpi-update to be sure and restarted the procedure. Same issue.
I checked the files I'm using:
From wget
total 1152
-rw-r--r-- 1 pi pi 315347 déc. 21 19:11 8188eu-20131209.tar.gz
-rw-r--r-- 1 pi pi 841734 déc. 10 01:22 8188eu.ko
-rw-r--r-- 1 pi pi 277 nov. 15 14:02 README
-rw-r--r-- 1 pi pi 13904 nov. 12 14:42 rtl8188eufw.bin
In /lib/modules/3.10.24+/kernel/drivers/net/wireless
-rw-r--r-- 1 root root 841734 déc. 10 01:22 8188eu.ko
Any idea?
Thanks for any help
From wget
total 1152
Any idea?
Thanks for any help
jmn - Grenoble, France
Hi jmn,jmn wrote:Hello
From wget
total 1152
Any idea?
Thanks for any help
3.10.24+ #614 requires a new version of the driver.
Take a look here and select the right version for 3.10.24+ #614 - 8188eu-20131219.tar.gz
If you get this type of error again just take a look at the link and with any luck you will find an update.
MrEngman
Thanks for the reply.
Sorry, I actually used your page but I read it probably too fast, and thought the date portion for #614 was still the same than for #608 and #610...
I missed the change from 20131209 to 20131219
Everything's allright now
Thanks a lot - and sorry again
No problem. Good to hear your wifi is OK again.jmn wrote:Thanks for the reply.
MrEngman
Hello Mr. Engman
I started with the traspi abourt 2 month ago and form the begining i was figthing with the instalation of the TL-WN725N V2 , and he is still wining, I followed precisesly your (bendit) instructions to install the
driver (kernel 3.10.24) and I couldn´t. This is the resultant screen:
drivepi@raspberrypi ~ $ lsusb
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
pi@raspberrypi ~ $ clear
pi@raspberrypi ~ $ wget https://dl.dropboxusercontent.com/u/802 ... 209.tar.gz
--2013-12-21 17:39:14-- https://dl.dropboxusercontent.com/u/802 ... 209.tar.gz
Resolviendo dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 54.225.191.40
Conectando con dl.dropboxusercontent.com (dl.dropboxusercontent.com)[54.225.191.40]:443... conectado.
Petición HTTP enviada, esperando respuesta... 200 OK
Longitud: 315347 (308K) [application/octet-stream]
Grabando a: “8188eu-20131209.tar.gz.1”
100%[======================================>] 315.347 193K/s en 1,6s
2013-12-21 17:39:23 (193 KB/s) - “8188eu-20131209.tar.gz.1” guardado [315347/315347]
pi@raspberrypi ~ $ tar -zxvf 8188eu-20131209.tar.gz
8188eu.ko
rtl8188eufw.bin
README
pi@raspberrypi ~ $ # run following two commands only if using version 3.10.xx+, not required for 3.6.11+
pi@raspberrypi ~ $ cat README <--check README file for adding
-bash: --check: No existe el fichero o el directorio
pi@raspberrypi ~ $ sudo cp rtl8188eufw.bin /lib/firmware/rtlwifi <--firmware if not already installed
-bash: --firmware: No existe el fichero o el directorio
pi@raspberrypi ~ $ sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
pi@raspberrypi ~ $ sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
pi@raspberrypi ~ $ sudo depmod -a
--2013-12-21 17:40:30-- https://dl.dropboxusercontent.com/u/802 ... 209.tar.gz
Resolviendo dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 54.225.82.235
Conectando con dl.dropboxusercontent.com (dl.dropboxusercontent.com)[54.225.82.235]:443... conectado.
Grabando a: “8188eu-20131209.tar.gz.2”
100%[======================================>] 315.347 200K/s en 1,5s
2013-12-21 17:40:38 (200 KB/s) - “8188eu-20131209.tar.gz.2” guardado [315347/315347]
8188eu.ko
rtl8188eufw.bin
README
IMPORTANT
This version of the rtl8188eu driver uses a seperate firmware file, rtl8188eufw.bin.
If this file is not already installed it needs to be copied to the directory
/lib/firmware/rtlwifi/ using the command :-
pi@raspberrypi ~ $ 3.10.24+ #610 - 8188eu-20131209.tar.gz
-bash: 3.10.24+: no se encontró la orden
Can you help me please? I´m trying to learn linux, I´m a rookie, and apreciate a lot your high help.
Regards, from Argentina.
8188eu.ko
rtl8188eufw.bin
README
8188eu.ko
rtl8188eufw.bin
README
IMPORTANT
Hello
Just the same error than me:
you use the 8188eu-20131209 version and not the 8188eu-20131219.
Redo with this one and it should be ok.
Regards,
Regards,
Hi otiumh,
I think jmn is probably correct. Check the version of 3.10.24+ you have. Use the command uname -a and I think it will show
3.10.24+ #614 uses driver 8188eu-20131219.tar.gz
MrEngman
Linux raspberrypi 3.10.24+ #614 PREEMPT Thu Dec 19 20:38:42 GMT 2013 armv6l GNU/Linux
MrEngman
Updated the OP to make the change in date code more obvious for 3.10.24 #614 and added some additional instructions to determine the Linux version so the correct driver is used (I hope
MrEngman
MrEngman
I am trying to install a TL WN725N on my new raspberry Pi.
I am in 3.6.11 #538 with a WN725N 0bda:8179.
I have installed 8188eu from 8188eu-20130830.tar.gz.
I can see wifi networks, and my Box, can connect but is not able to have an IP address. I tried with fixed IP, does not work. I have installed Wicd to help the management of wifi and network, no improvement.
Any clue ?
I would like to have confirmation for file: rtl8188eufw.bin is this file required for my version? It is not provided in the tar.gz file: 8188eu-20130830.tar.gz ...
Should I use one ? which one ? I tried to install the one from 20131113 with no success.
Any clue ?
