jperedadnr wrote:Hi all, hi MrEngman
I've got two Raspberry Pi with two TL-WN725N V2 wifi adapters. Both use Raspbian image.
*One has kernel 3.6.11+, and works perfectly (iwconfig states "Link Quality=97/100 Signal Level=66/100")
*The new one has kernel 3.10.25+ #622. This one has MrEngman's driver 8188eu-20131223 installed (both bin and ko files, following instructions at the beginning of this post), and wifi works but with a really slow connection. In fact, iwconfig states "Link Quality=0/100 Signal Level=2/100", even it's connected.
If I swap the adapters, the problem is still the same.
Any idea what could be happening?
Thanks in advance, MrEngman, for your great work.
Jose
I just compile the driver from someone else's source code. I'm not to keen on it especially having a separated firmware file which does make life awkward in certain cases. The driver has been heavily edited from the original and probably needs a fix to show signal levels correctly although there have been some changes recently. May be that they are not in the version you are using.
I use the 8188eu drivers on my main raspberry pi, now at 3.10.27+, and haven't had any problems with it so far.
MrEngman
