oki_one
how to play youtube video with omxplayer
Tue Dec 17, 2013 10:45 pm
Hi There,
Anyone try to play youtube videos with omxplayer?
Oki
gkreidl
Re: how to play youtube video with omxplayer
Wed Dec 18, 2013 4:32 am
You need to extract the video URL from the website first. youtube-dl can do this for you.
sudo apt-get install youtube-dl
youtube-dl can update itself to the newest version (you should do this regularly):
sudo youtube-dl -U
sudo youtube-dl -U
That's not a mistake: if installed for the first time, it needs two updates.
Then run
youtube-dl -g url
where "url" is the url of the website that contains the video. youtube-dl will output the video url then. Play it with
omxplayer "vurl"
where vurl is the video url you got from youtube-dl. You must use single or double quotes.
Or:
Install Minimal Kiosk Browser. Navigate to the video website. Click the "Play" icon in the toolbar. After a few seconds, omxplayer will start to play the video full screen. (youtube-dl must be installed!).
Minimal Kiosk Browser (kweb)
oki_one
Wed Dec 18, 2013 6:18 pm
Hi First, thanks for answer.
I am using arch linux.
I installed youtube-dl with below command
pacman -S youtube-dl
then , i create yt.py for catch and play url.
-------yt.py--------------------------------------
import sys, os
url=os.system('youtube-dl -g https://www.youtube.com/watch?v=vw61gCe2oqI')
os.system('omxplayer -o hdmi '+url)
rasult is below. What's wrong this picture?
[root@alarmpi home]# python yt.py
WARNING: Assuming --restrict-filenames since file system encoding cannot encode all charactes. Set the LC_ALL environment variable to fix this.
http://r1---sn-o097zned.googlevideo.com ... 1AA944E44C
File "yt.py", line 4, in <module>
TypeError: Can't convert 'int' object to str implicitly
oki_one
Wed Dec 18, 2013 6:52 pm
I also try
import sys, os
os.system('omxplayer -o hdmi '+str(url))
but still not working
gkreidl
Wed Dec 18, 2013 10:43 pm
os.system only returns the return code (an integer), not the output of the called program. Use something like
import subprocess
yta = ['youtube-dl', '-g',url]
yt = subprocess.Popen(yta,stdout=subprocess.PIPE,stderr=subprocess.PIPE)
(res,err) = yt.communicate()
if res and not err:
the output is in res ....
oki_one
Sun Dec 22, 2013 6:52 pm
Thanks for answer ,
I try to run this code i get below error.
if res and not err:
IndentationError: unexpected indent
my url is
url = 'https://www.youtube.com/watch?v=_hK-gQb9pUk'
This code suppose to be run url youtube link with omxplayer right?
Oki
gkreidl
Sun Dec 22, 2013 10:47 pm
Sorry, don't know how the indentation got in here; "if" must be at the beginning of the line in this example. (I'll edit the code above)
in "res" is the resulting video stream url, that can be played with omxplayer.
And no, 'https://www.youtube.com/watch?v=_hK-gQb9pUk' is not the URL that can be played with omxplayer, it's the the URL of the video page. youtube-dl can extract the video URL for you from this link.
oki_one
Mon Dec 23, 2013 3:12 pm
Ok here last status;
When i print res value with below code i got something like this,
b'http://r1---sn-p5qlsn7e.googlevideo.com ... 0409D69C\n'
import subprocess
url='https://www.youtube.com/watch?v=vw61gCe2oqI'
yta = ['youtube-dl', '-g',url, '--restrict-filenames']
if res and not err:
   print(res)
i think youtube url is b'YOUTUBE_URL\n
i try to play this url with below code
omxplayer -o hdmi YOUTUBE_URL
i got this;
[1] 645
[2] 646
[3] 647
[4] 648
[5] 649
[6] 650
-bash: 027b6a2a2: command not found
[7] 651
[8] 652
[9] 653
[10] 654
[11] 655
[12] 656
[13] 657
[14] 658
-bash: fexp: command not found
[15] 660
-bash: 78DC70C8E240D16.6AD4C89C0CD74A9280AACDF32386FE614AEBB427: command not found
[2] Done expire=1387836044
[3] Done sparams=id%2Cip%2Cipbits%2Citag%2Cratebypass%2Csource%2Cupn%2Cexpire
[4] Exit 127 id=bf0eb58 027b6a2a2
[5] Done sver=3
[6] Done upn=4TwE7O0enOY
[7] Done source=youtube
[8] Done ratebypass=yes
[9] Done mv=m
[10] Done key=yt5
[11] Exit 127 fexp =909717%2C932295%2C936912%2C936910%2C923305%2C936913%2C907231%2C907240%2C921090
[12] Done itag=22
[13] Done ms=au
[14]- Done ip=x.x.x.x
[15]+ Done mt=1387811411
I got correct url and try to play. But still nothing
gkreidl
Mon Dec 23, 2013 5:35 pm
you must strip the line feed (\n) from the result. And you must quote the video url.
Try from the command line first:
youtube-dl -g 'https://www.youtube.com/watch?v=vw61gCe2oqI'
that will give you the videourl
then
omxplayer 'videourl'
(in single or double quotes).
arti0504
Thu Apr 24, 2014 7:30 am
I have one Raspberry Pi where I run Motion. I can see video from my web camera. I must write 192.168.0.18:8081 to web browser and it's works in standard PC.
I would like use second Raspberry Pi to see this see video from my web camera. Can I use omxplayer for do this? What write to command line to do it?
oozo
Thu May 07, 2015 2:38 pm
When i use the Play button in the Kweb3 the youtube-dl find the video url, send to omxplayer and play it ?
This full screen from my sistem is running from an iframe. Can i integrate something to meke it run from omx ?
gkreidl
Thu May 07, 2015 8:13 pm
oozo wrote:When i use the Play button in the Kweb3 the youtube-dl find the video url, send to omxplayer and play it ?
If you use local html files and include the web content within iframes you can use the command interface of kweb. Command links as src of iframes can be used to start any kind of program. You can use omxplayerGUI to play youtube video (not only in windows but also without any interface full screen or in a dedicated screen area). Have a look at the omxplayerGUI manual for details.
oozo
Thu May 07, 2015 8:47 pm
K, Thx
Will do it today
S0AndS0
Sun May 24, 2015 7:03 pm
In one line to play YouTube from command line using an SSH connection;
omxplayer -o local --vol -2000 "$(youtube-dl -g '<YouTube_URL>')"
~ The -o can be set to "hdmi" or "both" for audio output
~ The --vol can be set between "-4000" to "-0" and controles the audio level
~ The "$()" is a trick for subsitution of output of one command's result into the input of another command; in this case the results of "youtube-dl -g '<>'"
~ The extra '' (single quotes) are to keep the "" (duble quotes) from interfearing with one another
This one command plus one line can likely be used in a script like so;
#!/bin/bash
YT_URL="$1"
omxplayer -o local --vol -2000 "$(youtube-dl -g $YT_URL)"
~ and run with
./script '<YouTube_URL>'
It'll take a few seconds to start but once started all the standard omx seem to work. Likely the above could be used to read a file as an array and then play videos as a playlist... but that's for another post...
~~ Edit ~~ after testing above suggestions I've updated commands and script example to match my working configs.
Additinal note; I start these commands within a session handler, screen or tmux, such that re-ataching after a disconnect over SSH isn't a problem ;-)
Happy hacking and modding.
~~ Edit - 2 ~~ ok so I couldn't help myself; here's a little script for playing YouTube links from a file, ie a playlist
#!/bin/bash
FileToPlay="$1"
for LINK in $(cat $FileToPlay)
do
    echo "Playing : $LINK"
    omxplayer -o hdmi --vol -1750 "$(youtube-dl -g $LINK)"
done
~ Save a file with links sepperated by new line and then feed the above script that file like so
./script '<file>'
~ I add to the file while playing with the following command
echo "<URL>" | tee -a /<file>
~ The "| tee -a" part pipes the echo'ed URL into the bottom of "file" (-a is append ;-))
~~ Edit 3 ~~
So my thoughts of just adding to the exsisting file didn't work; here's how I corected for that with another for-do-done check for uniqueness
#!/bin/bash
FileToPlay="$1"
for LINKs in $(cat $FileToPlay)
do
    omxplayer -o hdmi --vol -1500 $(youtube-dl -g $LINKs)
    echo "$LINKs" | tee -a $FileToPlay.played
done
for uLINK in $(sort $FileToPlay $FileToPlay.played | uniq -u)
do
    omxplayer -o hdmi --vol -1500 $(youtube-dl -g $uLINK)
done
echo "Removing : $FileToPlay.played"
rm $FileToPlay.played
echo "Exiting now"
~ The above will check once reaching the original end of $FileToPlay for anything that has been added, load those new entries as a new temp-list to play, then it cleans up after it's self without touching the original play-list file.
S0AndS0
Thu May 28, 2015 6:19 am
Here's a simple script for playing play-lists from YouTube via the raw play-list link from YouTube.
Dependancies; omxplayer youtube-dl lynx
Save in: /usr/local/sbin/yt_playList.sh
Grant permissions with: chmod +x /usr/local/sbin/typlayList.sh
Run with: yt_playList.sh "<Link_to_playList>"
#!/bin/bash
if [ ${#@} = 0 ]
then
	echo "I need a YouTube play-list link. Exiting now..."
	exit 1
fi
PlayList_Link=$1
OUT="both"
VOL="1550"
PlayLinks(){
	for lines in $(lynx --source "$PlayList_Link" | grep -i "watch?v=" | uniq -u | grep -o "data-video-id.*" | awk '{gsub("\""," "); print "https://youtube.com/watch?v="$2}')
	do
		echo "Playing $lines"
		echo "omxplayer -o $OUT --vol -$VOL \"\$(youtube-dl -g $lines)\""
		omxplayer -o $OUT --vol -$VOL "$(youtube-dl -g $lines)"
		clear
	done
PlayLinks
Usage and script walk-through;
The above first checks that an argumet is passed with the script; thats the [ ${#@} = 0 ] if then check bit.
Then $1 is read; this should be a play-list link that is publicly visable on YouTube. Example link : https://www.youtube.com/playlist?list=P ... wBX0K8uU2R
~ this has the "/playlist?list" section in the URL and has so far worked with the above script for parcing and playing.
Variables you'll want to edit are;
OUT="both"
VOL="1550"
~ the first selects output; hdmi and local and both are accepted arguments. The second selects volume and can range from 3000 to 0
Most of the heavy lifting is done with~
~ this first dumps the source of the given page link, then hunts for uniq "watch?v" portions of that page, then only outputs lines from those results that include "data-video-id" (the differance in -i vs -o ;-)), these lines are then cleaned up and formated with awk such that they can be fead into a file or input of another program
Finally the whole thing is wrapped up with
~ the $lines variable is set with the 'for do done' loop and is what the previous line provided.
Likely I'll combine the two such that there is a history temp file that's made and looked for durring run-time such that premeture exits and then re-running against the same play-list link will result in resuming the play-list on the very next video that was not priviously played... perhaps a GitHub repo will appier with the varias tools I've been working on some day soon...
CartoonSitty
Thu Feb 01, 2018 8:37 pm
I'm trying the steps in the top post, but when I try: youtube-dl -g url it says "failed to extract uploader nickname"
anyone know what gives??
gkreidl
Thu Feb 01, 2018 9:16 pm
perhaps you are using a very old version of youtube-dl.
If you are on Stretch, remove it and install a new version using pip
sudo pip install youtube-dl
mahjongg
Fri Feb 02, 2018 12:14 am
those steps are from 2015, so since several new versions of raspbian have come out, I would consider what is written as obsolete....
Return to “Python”
