Richard-TX
Volume was not properly unmounted ...
Tue Dec 31, 2013 12:23 am
Here is the fix for this annoying message.
# dmesg | grep corrupt
[   21.280705] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
# umount /boot
# git clone http://daniel-baumann.ch/git/software/dosfstools.git
# cd dosfstools
# make
cc -O2 -fomit-frame-pointer -D_GNU_SOURCE -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -Wextra -Wno-sign-compare -Wno-missing-field-initializers -Wmissing-prototypes -Wstrict-prototypes -g   -c -o fatlabel.o src/fatlabel.c
cc   mkfs.fat.o   -o mkfs.fat
# ./fsck.fat -V /dev/mmcblk0p1
fsck.fat 3.0.24 (2013-11-23)
0x25: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
1) Remove dirty bit
2) No action
? 1
Starting check/repair pass.
Starting verification pass.
Leaving filesystem unchanged.
/dev/mmcblk0p1: 14 files, 2383/7161 clusters
./fsck.fat -a /dev/mmcblk0p1
#mount /boot
Richard
Doing Unix since 1985.
Re: Volume was not properly unmounted ...
Tue Dec 31, 2013 6:59 am
That would work, but if you are running Raspbian it is much quicker to do
sudo apt-get install dosfstools
(which only needs to be done once)
then
sudo umount /boot
fsck -V /dev/mmcblk0p1
(reply to any messages as above)
mount /boot
No need to build dosfstools yourself as it has already been done for you :)
funky81
Wed Jan 01, 2014 7:54 pm
I've tried to use dosfstools taken from apt-get, but still can't remove this bug.
It seems the dosfstools package from apt-get (3.0.13-1) seems older than git files (3.0.24).
so the only solution just like @Richard-TX said, have to take the git then recompile.
Voila, the bug gone.
felisk
Sun Jan 05, 2014 9:07 am
same for me, dosfstools from apt-get did not show errors.
git cloned and built as per @Richard-TX, that fixed the problem.
fookey
Sat Jan 11, 2014 6:09 pm
Exact same scenario for me. Using apt-get dosfstools did not change the corrupt notification during boot. Per this thread:
http://www.raspberrypi.org/phpBB3/viewt ... 28&t=61879
Used this resulting in no change to the /boot corrupt message:
sudo fsck.vfat -w -r -l -a -v -t /dev/mmcblk0p5
So instead followed Richard's guidance to git clone and build the source and use fsck.fat. Walla! No more corrupt message during boot.
ripat
Tue Jan 28, 2014 7:31 am
Same here.
The dosfstools from the official raspbian repo did not clear the dirty bit. I had to compile the git sources as per the above post and use:
./fsck.fat -trawl /dev/mmcblk0p1
Using Linux command line usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
Broncus
Wed Feb 12, 2014 7:29 pm
In the event the reader does not understand what they read in Richard's comments. It took me (noob) a bit of playing around to understand what I needed to do. I am only listing the steps without the feedback.
The first time ./fsck.fat is ran, it should report "dirty bit" is set. Choose number 1. When the command is ran the second time, it will show the bit as clean.
Also, I was not running as a root user so I used "sudo" for each command.
Hopefully it will help. I know Richard's work has helped me.
Thanks and best regards!
Fred
	sudo umount /boot
	sudo git clone http://daniel-baumann.ch/git/software/dosfstools.git
	sudo cd dosfstools
	sudo make
	sudo ./fsck.fat -V /dev/mmcblk0p1
	sudo ./fsck.fat -a /dev/mmcblk0p1
	sudo mount /boot
Wed Feb 12, 2014 7:34 pm
Broncus you missed a step.
After make you need to use sudo make install to replace any existing version of the tools.
sharix
Mon Feb 17, 2014 11:22 am
I got this:
fsck.fat 3.0.25 (2014-01-17)
1) Remove dirty bit
2) No action
? 1
FATs differ but appear to be intact. Use which FAT ?
1) Use first FAT
2) Use second FAT
Which one should I choose?
ripat
Mon Feb 17, 2014 11:33 am
Option 1: Remove dirty bit
Or use this command:
Mon Feb 17, 2014 12:06 pm
sharix: That's a tricky one. One of the File Allocation Tables is wrong, but you can't tell which. You'll just have to make a guess, I suppose.
heatfanjohn
Tue Mar 04, 2014 7:39 pm
ripat wrote:Same here.
Thank you, this worked for me ...
beta-tester
Wed Mar 12, 2014 1:44 pm
i do not understand, why the official repository still contains an not working many years old outdated version of dosfstools.
isn't it possible to update that version in the repository? it is not understandable why every body who tries to fix the dirty bit, first has to run in to a not working solution, struggle around what's wrong, and has to search in the internet, to find the right working solution...
for what is the repository there, when it is not keeped up to date?!?! :x
ripat
Wed Mar 12, 2014 3:55 pm
The dosfstools v. 3.0.16-2 from the Jessie repo is working fine and successfully removes the dirty bit. If you don't want to make a full dist-upgrade, you can use the handy Debian preference pinning system and pick any package from Jessie without breaking your system. Here is how to do:
In /etc/apt/sources.list add:
# Jessie
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
Create your preference file: /etc/apt/preferences and add these lines:
Package: *
Pin: release n=wheezy
Pin-Priority: 800
Package: *
Pin: release n=jessie
Pin-Priority: 600
Update the packages list (it will take a while the first time!):
$ sudo apt-get update
Install dosfstools from Jessie
$ sudo apt-get -t jessie install dosfstools
Finaly umount /boot and run fsck:
$ sudo umount /boot
$ sudo fsck.vfat -trawl /dev/mmcblk0p1
chrisryall
Sun Mar 16, 2014 9:33 am
I've just seen this message appear (I'd done a simple sudo halt followed by system card backup)!
[   18.356472] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
All the above looks a bit scary. And when I run fsck as asked .. it warns of the perils of an unmounted file system!! Is this a real filesystem problem? Do I need to fix it? Is it as easy as and unmount of /boot, fsck, and remount (presumably all managed by the debian kernel)?
Sun Mar 16, 2014 9:38 am
Two ways to fix it.
1. Follow the instructions here to fix the dosfstools package.
2. Stick your card in a windows machine and use checkdisk (which can be driven from the GUI by right click and properties from file manager).
chrisryall
Sun Mar 16, 2014 10:59 am
Dougie, to the rescue again! :) I chose the desktop option (easier, better understood) and I had properly ejected it after my backup (was read only anyway?)
But checkdisk finds no errors. Though (bizarrely) I get a pop up offering to fix same errors when I plug it in :shock: So I'm presently reinstalling my February image. Don't think I'll lose much beyond updates as I've been attending to "other hobby" since then.
safull
Sun Mar 30, 2014 12:39 am
I there I downloaded and installed the package dostools-3.0.26. Build and installed, even copied to the /sbin and still get the error:
failed (code 6).
[FAIL] File system check failed. A log is being saved in /var/log/fsck/checkfs/ if that location is writable. Please repair the file system manually. ... failed!
Then on the log file I can read:
fsck.fat 3.0.26 (2014-03-07)
/dev/mmcblk0p1: 15 files, 2383/7161 clusters
open: No such file or directory
From the log I can see it's now running the build version 3.0.26. I can run it when I log in and seems to correct the error bit, when i run it with -frawl options. However the message is still there on every reboot, and waiting for user input.
I read on other forums I can disable the fsck editing the /etc/fstab, however will like to keep it.
Is really broken? I'm missing something?
rtek1000
Wed Apr 16, 2014 3:22 am
It work for me:
sudo umount /boot
sudo cd dosfstools
sudo make
sudo make install
sudo mount /boot
In the line: ./fsck.fat -V /dev/mmcblk0p1
I typed the number 1 and I pressed enter
Good luck! 8-)
NT4boy
Wed Apr 16, 2014 3:30 pm
One thing I'd add is that on my current noobs card, the boot drive isn't p1, but p5
sudo blkid -c /dev/null
/dev/mmcblk0p1: LABEL="RECOVERY" UUID="DB73-1078" TYPE="vfat"
/dev/mmcblk0p3: LABEL="SETTINGS" UUID="d1005177-0e28-44df-8dac-48faf7dc7c32" TYPE="ext4"
/dev/mmcblk0p5: LABEL="BOOT" UUID="039D-059C" TYPE="vfat"
/dev/mmcblk0p6: LABEL="root" UUID="2841057b-39e5-4612-87d5-c64ddea7edfb" TYPE="ext4"
sudo ./fsck.fat -V /dev/mmcblk0p5 detects the dirty bit so you say yes (1)
sudo ./fsck.fat -a /dev/mmcblk0p5 fixes the dirty bit
Otherwise, brilliant and fixed my error too. Thanks
darkform
Thu Apr 24, 2014 10:56 pm
Like most other Pi'ers, I was able to solve the problem with Richard-TX's post (The very first one)
So, installing with "sudo apt-get install dosfstools" didn't work.
And like NT4boy (First one above this post) said, try to identify the disc which gives the error. Most probably it is not p1. Mine was not P1 either, it was P5 instead. Try what he says and hopefully you'll solve this annoying error message.
croston
Thu Apr 24, 2014 11:51 pm
I've built Raspbian Jessie (clean image install, not an upgrade) and confirm that it has been fixed in the next version of Raspbian.
ripat
Sat May 24, 2014 4:41 pm
croston wrote:I've built Raspbian Jessie (clean image install, not an upgrade) and confirm that it has been fixed in the next version of Raspbian.
And for those who don't want to go the full dist upgrade way to Jessie I have posted here how to install only one package from Jessie using the Debian pinning system. Easy and gentle to your dependencies. Another advantage of using that method is that dosfstools will be automatically updated just like any other package from wheezy.
cweveritt
Sun Aug 24, 2014 8:24 pm
DougieLawsons method 2 using windows checkdisk apparently fixed it for me. Thanks all
liamkennedy
Fri Aug 29, 2014 5:41 am
ripat wrote:The dosfstools v. 3.0.16-2 from the Jessie repo is working fine and successfully removes the dirty bit. If you don't want to make a full dist-upgrade, you can use the handy Debian preference pinning system and pick any package from Jessie without breaking your system. Here is how to do:
Just wanted to add my thanks for this post. This fixed my problem and was much easier to complete than other solutions offered. Thanks so much
-Liam
