mattius
Saving files to usb in python?
Wed Mar 05, 2014 10:09 pm
Ok ok problems again,
I have a usb drive in, and i can see it mounted automatically in /devices/aabbcc/
if i check if that path exists in my script it does, when i save files there, it doesnt give any errors but the files do not appear on the usb drive.
Interestingly when my program exits or finishes its loop i get the usb drive mounted popup appearing (can i suppress this? its ruining my full screen program) which makes me think python is unmounting it?
Re: Saving files to usb in python?
Wed Mar 05, 2014 10:44 pm
You can't write to a USB drive without mounting it.
/dev/sda or /dev/sda1 is the raw device file, writing to those will overwrite the partition table and/or file allocation table and will destroy ALL data that may already exist on your USB stick.
sudo mkdir /media/usb
sudo mount /dev/sda1 /media/usb
nano /media/usb/filename.here.txt
mattius
Wed Mar 05, 2014 10:54 pm
Is that even in raspian, where i can see the usb drive is mounted in /media/aabbcc/
in the OS i can write files to that location, in python i cannot
Wed Mar 05, 2014 11:01 pm
If the drive is mounted then it depends on the mount options (uid, gid and umask).
Have a look with the mount command.
mattius
Wed Mar 05, 2014 11:10 pm
i dont understand, i have no control over the mount command as raspbian automounts usb drives.
Can i just mount it again?
jojopi
Wed Mar 05, 2014 11:21 pm
mattius wrote:in the OS i can write files to that location, in python i cannot
That suggests a problem with your code.
(Unless you are running the Python as a different user than the GUI. But then you would expect an error, not a silent failure.)
Wed Mar 05, 2014 11:23 pm
mount # see what it's got now.
sudo umount /media/foobar # unmount the media
sudo mount -o uid=pi,gid=pi,umask=0022 /dev/sda1 /media/foobar # mount with alternative options.
There's probably a auto-mounter config somewhere that defines what defaults you get, but as I don't use a GUI and I don't use auto-mounting on my RPi then I don't know for sure.
mattius
Wed Mar 05, 2014 11:57 pm
ok,
so manually mounting it made no difference, the drive seems to unmount when python runs
when i try and write to it, it does not exist.
Return to “Python”
