The Raspberry PI port of Darkplaces runs surprisingly well at 1080p with full audio support. Typical framerates during gameplay range between 20-30 fps at 1080p without overclocking. 1080p overclocked at 950mhz yields framerates of 35+. 720p without overclocking, up to 55 fps.
YouTube videos of Darkplaces engine running Half-Life maps, Quake mods and Quake on Raspberry PI, model B:
Raspberry PI running Darkplaces engine:
Darkplaces PI Version Installation and Configuration Guide
The following installation procedure has been tested with a new install of Raspbian (2014-01-07-wheezy-raspbian) with 256mb allocated to GPU:
Allocate at least 128mb memory for GPU
See http://elinux.org/RPiconfig#Memory for details.
Make sure system is up-to-date
sudo rpi-update
sudo rebootCode: Select all
mkdir ~/darkplaces
cd ~/darkplacesCode: Select all
wget https://github.com/autonomous1/darkplacesrpi/archive/dprpi_v1.1.zipCode: Select all
unzip dprpi_v1.1.zip
mv darkplacesrpi-dprpi_v1.1/* .
sudo dpkg -i darkplaces-rpi.debCode: Select all
wget ftp://ftp.idsoftware.com/idstuff/quake/quake106.ziphttp://linuxdocs.org/HOWTOs/Quake-HOWTO ... uake-files
Unpack game data
unzip quake106.zip
sudo apt-get install lhasa
lhasa e resource.1Note: replace pi with your username:
sudo usermod -a -G video piCode: Select all
darkplaces-sdlAdditional documentation
List of mods that run on RPi:
A list of mods known to work on the RPi. A section is included for mods suitable for children such as Nerf-Quake:
https://github.com/autonomous1/darkplac ... places-RPi
Mod installation guide:
https://github.com/autonomous1/darkplac ... Quake-mods
Video mode configuration:
https://github.com/autonomous1/darkplac ... figuration
Darkplaces engine configuration parameters:
https://github.com/autonomous1/darkplacesrpi/wiki
