Pencoys
/etc/network/interfaces for nearly all occasions
Tue Jun 05, 2012 10:43 pm
Having spent hours trying to get wireless WPA2 to work I have prepared this complete wireless dhcp interfaces config file for others to simply un hash their requirements.
I'm no expert and learning fast :-) but I hope this will help others at my level of understanding.
I know there will be many exceptions, errors etc, but I'm only trying to help..
the following is pasted into /etc/network/interfaces under the inface eth0 lines. i.e at the end of the file.
and then delete the hash from the commands that describe your wireless connection
and change UR_IP, UR_ESSID, UR_KEY ,and UR_PASS_KEY to reflect your routers setup
#; start of wireless bits
#; this command stays for all configs
auto wlan0
#; comments indicated by #;
#; commands indicated by #
#; remove the # to enable the command
#; if using static IP then....#
#iface wlan0 inet static
# address UR_IP
#gateway UR_ROUTER_IP
#netmask 255.255.255.0
#; otherwise use dhcp #
#iface wlan0 inet dhcp
#; OPEN wireless config #
#wireless-essid UR_ESSID
#wireless-mode managed
#; WEP wireless config #
#wireless-key UR_KEY
#; end of WEP config
#; WPA and WPA2 wireless config #
#; all command config lines above HERE to be #'ed except the entry auto wlan0
wpa-driver wext
wpa-ssid UR_ESSID
#; wpa-ap-scan is 1 for visible and 2 for hidden hubs
wpa-ap-scan 1
#; wpa-proto is WPA for WPA1 (aka WPA) or RSN for WPA2
wpa-proto WPA
#; wpa-pairwise and wpa-group is TKIP for WPA1 or CCMP for WPA2
wpa-pairwise TKIP
wpa-group TKIP
wpa-key-mgmt WPA-PSK
#; use "wpa_passphrase UR_ESSID UR_KEY" to generate UR_HEX_KEY
#; enter the result below
wpa-psk UR_HEX_KEY
# end of wireless bits
#; hope this helps someone. cheers
atek3
Re: /etc/network/interfaces for nearly all occasions
Fri Jun 08, 2012 6:08 am
Hmmm. I'm trying to connect to a WPA2-Personal protected WAP.
Here's my /etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
wpa-driver wext
wpa-ssid MYSSID
wpa-ap-scan 1
wpa-proto RSN
wpa-pairwise CCMP
wpa-group CCMP
wpa-psk MY_HEX_KEY
I'm using a Ralink RT3070 USB adapter, so I installed the rt2800usb driver. It appears to be seen just fine by the machine.
Here's my lsusb:
Bus 001 Device 005: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 001 Device 004: ID 099a:7202 Zippy Technology Corp.
when I try to go
sudo ifup wlan0
it gets to here:
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
and fails. Any ideas on how to troubleshoot this?
Thanks atek3.
Pencoys
Fri Jun 08, 2012 8:17 am
I'm no expert but it looks ok to my eyes.
I think the best way forward is to change your router's wireless security to open,
re-configure the /etc/network/interfaces to:-
auto wlan0
Try connecting and if you still can't connect, look elsewhere for the problem.
However if you are successful, change the wireless security to WEP
auto wlan0
wireless-key UR_KEY
and so-on till you get up to your required security level.
Don't forget that case and speiling is important, as is whitespace between e.g ..
Wireless-essid would not work (capital W rather than lowercase w)
wireless - essid would not work ( whitespace between the - )
The same goes for all other information, especially with UR-HEX-KEY where its very easy to insert a problem. ( Did you pick up the deliberate spelling error ?)
Wireless-routers are obtainable from bootsales for a few quid these days, get one as a test rig.
I have one permenently set up for test purposes. That way your normal wireless is uneffected while 'playing' and you can take your time over the process of troubleshooting without 'She-who-must be-obeyed' shouting at you for not having access to her electronic 'garden-gate' ( what I call twitter)
hope this helps, I know how frustrating it is when you are sure everythin is correct, but realise it can't be.
all the best, Mike
wallarug
Sat Sep 22, 2012 10:31 am
by Pencoys » Fri Jun 08, 2012 7:17 pm
That is not always an option for people. :lol:
wallarug
Sat Sep 22, 2012 11:25 am
atek3 wrote:Hmmm. I'm trying to connect to a WPA2-Personal protected WAP.
auto lo
auto wlan0
wpa-driver wext
wpa-ssid MYSSID
wpa-ap-scan 1
wpa-proto RSN
wpa-pairwise CCMP
wpa-group CCMP
wpa-psk MY_HEX_KEY
Here's my lsusb:
when I try to go
sudo ifup wlan0
it gets to here:
Thanks atek3.
You shouldn't need to put in so much detail:
auto wlan0
wpa-driver wext
wpa-ssid MYSSID
wpa-ap-scan 1
wpa-proto RSN
wpa-pairwise CCMP
wpa-group CCMP
wpa-psk MY_HEX_KEY
What I have in my /etc/network/interfaces file is just:
auto wlan0
wpa-ssid "<network name>"
wpa-psk "<password>"
If you want to use a wpa_supplicant hexidecimal code instead of your letters and numbers password:
1. type in a terminal or Command line:
wpa_supplicant
2. Follow the instructions left there for that program to get a hexidecimal number for wireless network.
3. Paste that hex-number into the wpa-psk area of /etc/network/interfaces
Good Luck.
jun3rd
Wed Mar 05, 2014 7:21 pm
Thank you so much. This was so helpful.
Phlip_
Wed Jul 16, 2014 6:41 pm
Due to a broken home network that relies on big corps to get fixed (hah!), i have this topology:
- notebook -> ethernet cable -> hub -> cable -> RPi -> eth0
- smartphone tether to internet -> USB -> usb0
The problem is whenever I ifup usb0 I can get on the internet, but the instant I ifup eth0, the internet lapses.
Per post TBD, I added inet to my usb0 in /etc/network/interfaces:
iface eth0 inet auto
iface usb0 inet auto
Now the newbie questions. To get internet on my usb0, do I reorder the lines? That would leave eth0 open for inet if Big Data gets off its butt and fixes our home network.
Or do I take out the inet on eth0? Do I leave nothing there? or do I provide an alternative to inet?
iface eth0 ? auto
(For extra credit, someone can help me get Win8 to share my inet on eth0! Yes, I hit the button on the source network's Properties tab;)
bd3k
Thu Sep 04, 2014 12:37 am
I was having all kinds of issues getting my WIFI working - then found this - great info - only thing I had to figure out is that wpa-ssid has to be in quotes - that's a big FYI - if you use hex value for wpa-psk you don't need quotes - but if you put in alphanumeric probably does need quotes.
Robindubois
Wed Jun 10, 2015 2:14 am
Guy, I spent hours trying to get this to work, hours away from kids back aching, etc etc... I read a dozen confident instructions that either crashed my machine and totally corrupted the OS, (I have a backup card so not a big deal) and it's darn hard to do that. Then by chance I found your methodology you so generously took time to publish. You started out saying it works because you spent time verifying it, not just a splat of code with no statement to the effect that it works.... Your stuff worked. Immediately. My two crushed vertebrae thank you thank you thank you
Robin du Bois
robin.dubois@gmail.com
T4b
Fri May 06, 2016 2:14 pm
You are making it more complicated that it is.
In fact
allow-hotplug wlan0 #this doesn't hurt but is only useful for usb-wifi dongles
auto wlan0
  wpa-ssid "SSID"
  wpa-psk "Passphrase"
at the end of the file (commenting out anything else regarding wlan which might already be there) should do the job in 90% of cases (that is, standard wlan networks with visible SSIDs and using WPA-security {which is the only secure one} based on passhrases). Some (usually corporate or university) networks use another means of authentication (user+password) which I don't know how to configure like this.
For more than one adapter add anlogous stanzas with wlan0 replaced with wlan1 etc.
I know this is gravedigging, but this thread, old as it is, is a prominent result in search engines.
stderr
Fri May 06, 2016 2:22 pm
T4b wrote:You are making it more complicated that it is.
In fact
auto wlan0
  wpa-ssid "SSID"
So now you are adding a currently live element claiming that you should set up your wifi stuff in the /etc/network/interfaces file? Is that really helping?
