raspi2807
setting up iptables
Wed Aug 27, 2014 1:06 am
When I type in sudo /sbin/iptables -L, I get the following.
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
But if I type sudo service iptables start, I get unrecognized service.
I assume I already have iptables installed. But how do I run iptables? There is no iptables under /etc/init.d/
jojopi
Re: setting up iptables
Wed Aug 27, 2014 6:16 am
Assuming you are running Raspbian, and know what iptables rules you want, just "sudo apt-get install iptables-persistent". Then put your rules in /etc/iptables/rules.v4 and they will be loaded at boot.
Otherwise, what kind of firewall or routing are you trying to achieve?
Richard-TX
Wed Aug 27, 2014 6:32 am
apt-get install fwbuilder
Richard
Doing Unix since 1985.
raspi2807
Wed Aug 27, 2014 7:28 am
Thank you. It is working. I just want to secure the system with firewall.
