USB redirector
Hi all hope you can help.
Im trying to install this program USB Redirector for Linux
http://www.incentivespro.com/downloads.html
running latest debian for raspberry
When tring to install i get the famus kernel error could somebody who knows linux help me so i could install this???
Re: USB redirector
I suspect before anyone will be able to help you you'll need to tell us what "the famous kernel error" actually is. Probably also exactly what version you downloaded since there are a number of arm options
Re: USB redirector
missing kernel headers and kernel sources. sorry forgot that.
i tried the arm and armb and arm5 was a no go!
Re: USB redirector
You might have more luck with this one: http://usbip.sourceforge.net/ - I've seen it used on an embedded linux IP KVM running on some kind of ARM processor.
Re: USB redirector
Without the kernel headers it won't matter which of the downloads you try. You need the kernel headers first. The version of the kernel headers you need depends upon the version of the kernel you are running.
will tell you that, and then we should be able to point you in the right direction
uname -a
Re: USB redirector
Thanks Wendo
Here is my result of the uname command
Linux raspberrypi 3.1.9+ #125 PREEMPT Sun Jun 17 16:09:36 BST 2012 armv6l GNU/Linux
Re: USB redirector
apt-get install make gcc linux-headers-`uname -r`
this command does not work either
could not find package
Re: USB redirector
Hi i also want to install this usbredirector programm but cant get it to work. it would be nice if somebody has installed this programm or usbip correctly could provide some installation howto
Re: USB redirector
Nice to see im not the only one. now we can only hope that there is a real "guro" that can get it working for us NOOBS.
Re: USB redirector
i found this how to for compiling the driver.:
http://www.incentivespro.com/usb-server-install.html
could somebody with more linux knowledge make this working on the raspi?
Thanks in advance
cubii
Thanks in advance
cubii
Re: USB redirector
hi,
i tried it again with usbip:
After this how to, i tried to complie the drivers : http://www.howtoforge.com/how-to-set-up ... n-lenny-p2
starting at the point "aptidude update"
but when doing "m-a a-i usbip-source" i get errors like: hostname: host or name not known
and with 22 % it stops with an error "make error 2"
what is wrong?
how can get the log file which is produced during this step, so i can post it here?
any help appreciated!
what is wrong?
Re: USB redirector
Here is how to get USBIP working on raspberry pi:
Note: I have only done this on the debian wheezy beta. May or may not work on anything else.
Compiling the drivers (if the official kernel enables the modules this step will not be necessary):
First, make sure you have updated to the latest kernel, modules, firmware, etc. Then:
Then open .config with an editor and add this at the end:
Then:
Then install usbip:
Then to load the host driver (for sharing usb devices):
To list devices:
Note the busid on the device you want to share and then:
which should respond with:
Then on the client:
and you should see the device that is connected to the pi in the lsusb output on the client (and you should be able to use it).
Note that listing and/or attaching on the client may sometimes fail the first time in which case you may need to issue the bind command again on the pi.
sudo apt-get install git
git clone git://github.com/raspberrypi/linux.git kernel
cd kernel
wget https://raw.github.com/raspberrypi/firmware/master/extra/Module.symvers
zcat /proc/config.gz > .config
CONFIG_USBIP_CORE=m
CONFIG_USBIP_VHCI_HCD=m
CONFIG_USBIP_HOST=m
CONFIG_USBIP_DEBUG=n
make oldconfig
make LOCALVERSION=+ modules_prepare
make SUBDIRS=drivers/staging/usbip
sudo make SUBDIRS=drivers/staging/usbip modules_install
sudo depmod -a
sudo apt-get install usbip
sudo modprobe usbip-host
sudo usbip list -l
sudo usbip bind --busid <busid>
bind device on busid <busid>: complete
sudo modprobe vhci-hcd
usbip list --remote <pi ip>
sudo usbip attach --host <pi ip> --busid <busid>
lsusb
Re: USB redirector
Is there a windows reciver that can be used with USBIP?
Re: USB redirector
There is a windows client on their website: http://usbip.sourceforge.net/ although I have never used it.
Re: USB redirector
@secretagent you are my hero!
Will try it a soon as i can !
Re: USB redirector
I tried two times to install usbip,
but i get errors.
First, i have to say i dont know i f i have updated all files correctly. I used wheezy beta and used apt-get update and apt-get upgrade, also aptitude update and - upgrade and ussed the hexxeh updater for firmware ( http://hexxeh.net/?p=328117855 ).
This part:
gives me errors like:
make*** no target specified and similar errors.
and "sudo modprobe usbip-host"
gives me an Fatal error "Fatal: USBip-host not found)
I also cant fin the folder "kernel", where git should have made a clon of the kernel. Is this expected behaviour (for. Ex. folder kernel gets deletet after cloning or something?)
Some hints , please?
but i get errors.
This part:
make oldconfig
sudo depmod -a
Re: USB redirector
So after many tries i found that i have to activate a swap file:
http://www.raspberrypi.org/phpBB3/viewt ... 03#p128303
and now it installs correctly and binds the usb-device correctly.
Now the windows client makes problem,
i cant connect, because it doesnt find any device in the network....
Tried it with the version 1 and 2.....
Re: USB redirector
Sorry, missed the notification somehow. Yes, there are many things that will fail without a swap, so I've always had it enabled and forgot to mention it in the instructions.
I can't help with the windows client but if you want to make sure that the setup on the Pi is correct you could run a ubuntu live image in virtualbox and test attaching the device to it using the linux client instructions. If that works then the problem is most likely on the windows side.
Re: USB redirector
hey guys can anyone please help me everything worked for me until sudo modprobe usbip-host it says FATAL: Module usbip-host not found. i already have swap activated i am using raspberian
thank you
thank you
Re: USB redirector
Hey,
I'm also having some trouble running usbip. everything runs smoothly up to the point where I'm supposed to run
every time I try I get the following error message:
I'm using rasbian with the newest kernel (3.2.27+) and I have done all the package upgrades available, meaning I've run apt-get update && upgrade.
ERROR: could not insert 'usbip_host': Exec format error
Re: USB redirector
I have installed the USBIP but the entire system hangs when I bind. I have to pull the power plug to restart.
Re: USB redirector
Having followed the instructions above I now have my Pi sharing both a Philips camera and a USB RS-232 port. I also have a working install of the windows client. Unfortunately, the client will not connect to the host and running usbipd --debug on the Pi gives a message of 'version mismatch: 262 273'.
A google search for this error provides a post which refers to an OpenWrt patch file but I am unsure as to whether or not this is applicable here. Downloading the patch file and attempting to patch with it results in a message to the effect that it cannot find the file to be patched. Having expended my meagre knowledge of linux I'd like to ask if anyone has any pointers. I have tried both versions of the windows client. Windows OS is 7 Ultimate 64 bit.
Many thanks,
Many thanks,
Re: USB redirector
After further research and some trial and error I have the Incentives Pro USB redirector working. I found that the package that worked for me was this one http://www.incentivespro.com/usb-redire ... abi.tar.gz Within the tarball there is a readme file that gives good guidance including the need to get the linux source and headers. An excellent guide for this was posted at http://www.raspberrypi.org/phpBB3/viewt ... 58#p179845 The only problem I had was in the section which begins KSRC='pwd'. This did not work for me but using the pwd command and entering the symbolic link longhand did.
Re: USB redirector
I have a problem to create simlinks and so I have an error when I install usb redirector (Kernel sources or kernel headers directory not found. Please install the corresponding package first)
Can you help me ?
Gé
Can you help me ?
Gé
DungBeetle wrote:After further research and some trial and error I have the Incentives Pro USB redirector working. I found that the package that worked for me was this one http://www.incentivespro.com/usb-redire ... abi.tar.gz Within the tarball there is a readme file that gives good guidance including the need to get the linux source and headers. An excellent guide for this was posted at http://www.raspberrypi.org/phpBB3/viewt ... 58#p179845 The only problem I had was in the section which begins KSRC='pwd'. This did not work for me but using the pwd command and entering the symbolic link longhand did.
Re: USB redirector
If you can explain what your problem with simlinks is I'll do my best to help. As I said in an earlier post my linux knowledge is really quite meagre and I have undergone an incredibly steep learning curve largely helped by these forums. Did you work through the guide in this thread http://www.raspberrypi.org/phpBB3/viewt ... 50#p175850geronymo80 wrote:Hi,
Can you help me ?
