harold95
[solved] trying to get usb audio to work
Mon Oct 06, 2014 12:52 pm
i have a usb sound dongle, cmedia.
while i can see it gets recognized on boot up, i can't seem to get and sound out of it.
i made a couple changes to alsa-base.conf
# autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
# Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd && { /sbin/modprobe --quiet snd-i$
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi && { /sbin/modpro$
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 && { /sbin/modpro$
# Keep snd-pcsp from beeing loaded as first soundcard
options snd-pcsp index=-2
# Keep snd-usb-audio from beeing loaded as first soundcard
options snd-usb-audio index=-0    <<< changed this from 2 to 0
# Prevent abnormal drivers from grabbing index 0
options bt87x index=-2
options cx88_alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
options snd-usb-audio nrpacks=-0  <<<added this line
when i run alsa mixer, i can only see the bcm2835 sound device, which i think is the built in card for the pi.
my cmedia device is not present.
what am i missing?
i must have forgot to do something, but in all my searches, modifying the alsa-base.conf is the only thing i can see that needs to be done
thanks!
Harold
1. B pi, usb ext pwrd hdd 500gb, pwrd usb hub 2a (pwrs pi), wifi, vga adptr, wired kb/mouse, usb audio.
2. B pi, hdlss. adaptd for use as an IRLP node. IRLP rev 3 board wired to gpio, usb audio, Alinco DR135 2 meter ham radio(www.irlp.net)
Douglas6
Re: trying to get usb audio to work
Mon Oct 06, 2014 1:20 pm
That wants to be
options snd-usb-audio index=0
not '-0'. Also, remove 'options snd-usb-audio nrpacks=-0' It's wrong and not needed. Reboot.
harold95
Mon Oct 06, 2014 3:39 pm
thank you for the reply.
i did as you suggested, and then, rebooted.
the sound still comes out via the pie speaker output, not the cmedia usb dongle.
alsamixer still only shows the broadcom bcm2835 device, no other devices are present.
any ideas?
thank you.
Harold
Douglas6
Mon Oct 06, 2014 4:06 pm
Ok, let's see the output from
lsusb
aplayer -l
and
aplayer -L
I'd also check the
dmesg
command, as it sounds like your device is not getting recognized by the OS.
harold95
Mon Oct 06, 2014 4:46 pm
while you were posting that i found something on the web, a tutorial as it were.
http://computers.tutsplus.com/articles/ ... -mac-55876
basically, you comment out the line in alsa-base.conf that reads
#options snd-usb-audio index=-0
however i left the line you suggested in:
rebooted and then all was well.
thanks fur ur help!
