Hello guys,
I need disable the automount Pen drive in raspberry, I tried edit the [ pcmanfm.conf ] , but nothing.
In my Debian have the hotplug, and i can disable using the udev. The raspberry have this options ?
regards,
Re: Disable automount
Open the file manager (pcmanfm); go to the settings / preferences. In one of the tabs of this dialog you can disable all the automount stuff...
HTH
Dirk.
HTH
Dirk.
Or, you can edit/create the following file:
~/.config/pcmanfm/LXDE/pcmanfm.conf
and make sure it contains:
Doing this is part of my standard "tasks to make Raspbian usable".
[volume]
mount_on_startup=0
mount_removable=0
Thanks guys !
Looks like the path has changed, the config file now seems to be.
/home/pi/.config/pcmanfm/LXDE-pi/pcmanfm.conf
