Python script problem in terminal
Posted: Fri Jan 16, 2015 1:36 pm
Hi everybody,
I really have an interesting problem. My Python script runs very well, without mistakes if I use Idle(3) in grafical mode, but if I start the same program in terminal, it has some mistakes. In this case the main problem, that it does not use the interrupts
(GPIO.add_event_detect and so on). Have You ever met this funny things?
This is a net radio program with a 2x16 LCD display and 4 push buttons for changing the stations and the volume. The push buttons work in interrupts. I attache the code, You can try it, I like it.
First a short initial text, after a scrolling text shows the radio station, and the details of the song.
When I start the program in terminal, the music and the scrolling text starts according to the expectations, but I can not use the push buttons, so I suppose, that the interrupt system does not work. In the terminal there are not warnings, but it shows only the mpc datas.
[code]#!/usr/bin/python
# The wiring for the LCD is as follows:
# 1 : GND
# 2 : 5V
# 3 : Contrast (0-5V)*
# 4 : RS (Register Select)
# 5 : R/W (Read Write) - GROUND THIS PIN! We do not want the LCD to send anything to the Pi @ 5v
# 6 : Enable or Strobe
# 7 : Data Bit 0 - NOT USED
# 8 : Data Bit 1 - NOT USED
# 9 : Data Bit 2 - NOT USED
# 10: Data Bit 3 - NOT USED
# 11: Data Bit 4
# 12: Data Bit 5
# 13: Data Bit 6
# 14: Data Bit 7
# 15: LCD Backlight +5V
# 16: LCD Backlight GND (Red)
#import
import RPi.GPIO as GPIO
import time
import os
# Define GPIO to LCD mapping
LCD_RS = 25
LCD_E = 8
LCD_D4 = 7
LCD_D5 = 10
LCD_D6 = 9
LCD_D7 = 11
LCD_LI = 4
# Define GPIO for Radio Controls
NEXT = 22
PREV = 27
VOLUP = 23
VOLDO = 24
# Define some device constants
LCD_WIDTH = 16 # Maximum characters per line
LCD_CHR = True
LCD_CMD = False
LCD_LINE_1 = 0x80 # LCD RAM address for the 1st line
LCD_LINE_2 = 0xC0 # LCD RAM address for the 2nd line
# Timing constants
E_PULSE = 0.0001 #0.00005
E_DELAY = 0.0001 #0.00005
GPIO.setwarnings(False)
def main():
# Main program block
GPIO.setmode(GPIO.BCM) # Use BCM GPIO numbers
GPIO.setup(NEXT, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(PREV, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(VOLUP, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(VOLDO, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.add_event_detect(NEXT, GPIO.FALLING, bouncetime=800)
GPIO.add_event_callback(NEXT,nextsong)
GPIO.add_event_detect(PREV, GPIO.FALLING, bouncetime=800)
GPIO.add_event_callback(PREV,prevsong)
GPIO.add_event_detect(VOLUP,GPIO.FALLING, bouncetime=800)
GPIO.add_event_callback(VOLUP,volumeup)
GPIO.add_event_detect(VOLDO,GPIO.FALLING, bouncetime=800)
GPIO.add_event_callback(VOLDO,volumedown)
GPIO.setup(LCD_E, GPIO.OUT) # E
GPIO.setup(LCD_RS, GPIO.OUT) # RS
GPIO.setup(LCD_D4, GPIO.OUT) # DB4
GPIO.setup(LCD_D5, GPIO.OUT) # DB5
GPIO.setup(LCD_D6, GPIO.OUT) # DB6
GPIO.setup(LCD_D7, GPIO.OUT) # DB7
GPIO.setup(LCD_LI, GPIO.OUT) # Backlight
os.system("mpc clear")
os.system("mpc load dplist")
os.system("mpc volume 30")
while 1:
a = 0
b = 1
GPIO.output(LCD_LI, False) # Initialise display
os.system("mpc play")
time.sleep(0.4)
lcd_init()
text()
while (a <= b):
f=os.popen("mpc current")
title = f.read()
title = title[:-1] #delete EOF signal from the end
str_pad = " " * 15 #15 space at the front of the line
title = str_pad + title
b = len(title)
lcd_byte(LCD_LINE_1, LCD_CMD)
lcd_text = title[a:(a+16)]
a += 1
lcd_string(lcd_text,1)
time.sleep(0.4)
if GPIO.event_detected(NEXT): #if you press the NEXT button
a = 0
text()
if GPIO.event_detected(PREV): #if you press the PREV button
a = 0
text()
if (GPIO.input(VOLUP) == False) & (GPIO.input(VOLDO) == False):
b = 0 #if press both VOL button, program pause
os.system("mpc stop")
GPIO.remove_event_detect(VOLUP)
text2()
GPIO.output(LCD_LI, True)
GPIO.wait_for_edge(VOLUP, GPIO.FALLING)
GPIO.add_event_detect(VOLUP,GPIO.FALLING, bouncetime=300)
def text(): # Send some text
lcd_string("Raspberry Pi",2)
lcd_byte(LCD_LINE_2, LCD_CMD)
lcd_string("Internet Radio",2)
time.sleep(2)
def text2(): # Send some text
lcd_string("Bye bye!",2)
time.sleep(2)
def nextsong(NEXT):
f = os.popen("mpc -f %position% current")
current_Pos = int(f.read())
if current_Pos == 5:
os.system("mpc play 1")
elif current_Pos < 5:
os.system("mpc next")
time.sleep(0.3)
def prevsong(PREV):
os.system("mpc prev")
time.sleep(0.3)
def volumeup(VOLUP):
while GPIO.input(VOLUP) == False:
os.system("mpc volume +3")
time.sleep(0.3)
def volumedown(VOLDO):
while GPIO.input(VOLDO) == False:
os.system("mpc volume -3")
time.sleep(0.3)
def lcd_init():
time.sleep(0.05)
lcd_byte(0x33,LCD_CMD)
time.sleep(0.01)
lcd_byte(0x32,LCD_CMD)
time.sleep(0.001)
lcd_byte(0x28,LCD_CMD) # 4 bits, 2 lines, 5x8 dots
lcd_byte(0x0C,LCD_CMD) # Display on, Cursor off, Blinking off
lcd_byte(0x06,LCD_CMD) # Cursor increment
lcd_byte(0x02,LCD_CMD) # DD RAM Address = 0
time.sleep(0.005)
lcd_byte(0x01,LCD_CMD) # Clear Display
time.sleep(0.005)
def lcd_string(message,style):
# Send string to display
# style=1 Left justified
# style=2 Centred
# style=3 Right justified
if style==1:
message = message.ljust(LCD_WIDTH," ")
elif style==2:
message = message.center(LCD_WIDTH," ")
elif style==3:
message = message.rjust(LCD_WIDTH," ")
for i in range(LCD_WIDTH):
omessage = ord(message[i])
if omessage==0x70: # p
omessage = 0xF0
elif omessage==0x79: # y
omessage = 0xF9
elif omessage==0x71: # q
omessage = 0xF1
elif omessage==0x67: # g
omessage = 0xE7
elif omessage==0x6A: # j
omessage = 0xEA
else:
lcd_byte(omessage,LCD_CHR)
lcd_byte(ord(message[i]),LCD_CHR)
def lcd_byte(bits, mode):
# Send byte to data pins
# bits = data
# mode = True for character
# False for command
GPIO.output(LCD_RS, mode) # RS
# High bits
GPIO.output(LCD_D4, False)
GPIO.output(LCD_D5, False)
GPIO.output(LCD_D6, False)
GPIO.output(LCD_D7, False)
if bits&0x10==0x10:
GPIO.output(LCD_D4, True)
if bits&0x20==0x20:
GPIO.output(LCD_D5, True)
if bits&0x40==0x40:
GPIO.output(LCD_D6, True)
if bits&0x80==0x80:
GPIO.output(LCD_D7, True)
# Toggle 'Enable' pin
time.sleep(E_DELAY)
GPIO.output(LCD_E, True)
time.sleep(E_PULSE)
GPIO.output(LCD_E, False)
time.sleep(E_DELAY)
# Low bits
if bits&0x01==0x01:
if bits&0x02==0x02:
if bits&0x04==0x04:
if bits&0x08==0x08:
time.sleep(E_DELAY)
time.sleep(E_PULSE)
time.sleep(E_DELAY)
if __name__ == '__main__':
main()
[code]
