We use some essential cookies to make our website work.
We use optional cookies, as detailed in our cookie policy, to remember your settings and understand how you use our website.
Stryder
Can I use the RPi Debug Probe on a Pi 4
Sun Dec 01, 2024 1:18 pm
Hi I was watching a video on the Debug probe and they said it can be used to debug Pi boards. Is it possible to debug a Pi 4 with it? I have a Pi 4 that does not work, and I tried fixes that was said to me on a previous forum post but none of them helped.
wildfire
Re: Can I use the RPi Debug Probe on a Pi 4
Sun Dec 01, 2024 1:37 pm
Did you follow the suggestions in the boot problem sticky as thagrol suggested?
If so what were the results?
I'm not aware of what debug probe you have, perhaps providing us with a link would help?
E8 85 A2 40 C9 40 81 94 40 81 95 40 89 84 89 96 A3
Still NF Shirls
FTrevorGowen
Sun Dec 01, 2024 3:28 pm
If your "debug probe" is one of these: https://www.cpmspectrepi.uk/raspberry_p ... Probe.html then, yes, via the appropriate GPIO connector cable supplied with the probe. However, if you don't have that probe a "good value" alternative is one of these USB to serial (3.3V) devices: https://www.cpmspectrepi.uk/raspberry_p ... nsole_Stub (there are other, alternative, serial devices within that page).
Trev.
Running Bookworm on a Pi5, a P500 and two P4B's but still using Bullseye or Buster on other (older) Pi's and the P400 I often post from. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm for notes & screenshots etc.
Stryder
Fri Dec 06, 2024 11:30 am
I did follow the suggestions and there wasn't really any difference, it was a while ago, So I don't really remember what happened.
Stryder
Fri Dec 06, 2024 11:31 am
Trev.
That's the one I have and I ended up finding the answer in the docs eventually. Thanks
thagrol
Fri Dec 06, 2024 12:34 pm
I did? When?
wildfire
Fri Dec 06, 2024 1:30 pm
I did? When?
In a different thread viewtopic.php?t=374245
Their was no response from the OP in that one.
Still NF Shirls
thagrol
Fri Dec 06, 2024 2:50 pm
I did? When?
Ah. Fair enough.
