mehstg
Changing Window Manager on Raspbian
Tue Oct 02, 2012 5:28 pm
Hi all
Just a quick question, as I am struggling here and I can't seem to find much info searching through the forums.
I am attempting to swap the default window manager from LXDE (Openbox) to Ratpoison, however I am obviously editing the wrong file, as when I reboot, it still opens LXDE.
I have installed Ratpoison via apt-get, I then run the following:
update-alternatives --config x-window-manager
I am given three options. Openbox Auto, Openbox Manual and Ratpoison. I select Ratpoison and exit.
Any ideas. I am guessing it is controlled by a different file, however I cannot work it out. Some posts refer to a $HOME/.xinitrc however I co not have this file in my home folder.
Paul
Metatronin
Re: Changing Window Manager on Raspbian
Tue Oct 02, 2012 10:02 pm
No, you most likely changed it to Ratpoison. LXDE is the desktop environment, where as Ratpoison, Openbox, Fluxbox, etc, are the window manager.
mehstg
Thu Oct 04, 2012 7:10 am
I'm not so sure. That was my initial thought, however I then proceeded to uninstall LXDE. I am now presented with the LightDM login box, it has only one option on it (Openbox).
Is anyone able to point me in the right direction? I am basically looking to strip LXDE from raspbian. I am trying to get it so it boots straight in to Ratpoison. (I'll be using the Pi to run a single app fullscreen)
penoycentral
Wed Nov 21, 2012 8:14 am
Hiya.. i've been using raspbian+ratpoison automatically starting a web browser in a kiosk mode. might not be direct but maybe similar on your needs.
Start user pi at startup
pi@raspberrypi:~$ grep pi /etc/inittab
1:2345:respawn:/bin/login -f pi tty1 </dev/tty1 >/dev/tty1 2>&1
pi@raspberrypi:~$ cat /home/pi/.bash_profile
if [ -z "$DISPLAY" ] && [ $(tty) == /dev/tty1 ]; then
    startx
fi
Set ratpoison's config file
pi@raspberrypi:~$ cat /home/pi/.xinitrc
exec ratpoison
pi@raspberrypi:~$ cat /home/pi/.ratpoisonrc
exec <what-ever-your-program>
this will automatically start ratpoison with exec to a program. hopefully it will give you idea on how to solve your issue ;)
obiwan
Sat May 25, 2013 7:09 pm
Raspbian is a Debian Linux version, so as Debian, there is specific command to change settings (update-alternatives), to configure (dpkg-reconfigure) and to manage (apt-get, dpkg).
That's safer than personal scripts which can be erased by default setting at reconfiguration or reinstallation, and which can break Debian configuration.
To change default x-session-manager just use the command :
$ sudo update-alternatives --config x-session-manager
You will see it was by default set to lxde. The x-session-manager manage the x-window-manager. By default it is lxde session-manager with openbox window-manager (and lxde desktop environment inside openbox... but you can use openbox without desktop environment, which is nice too, and faster with key shortcuts, context menu, and lightness. Take a look at openbox website.)
Above all, there is the display-manager. Raspbian use LightDM display manager (see /etc/X11/default-display-manager), So configuration, like auto-start user, can be found in /etc/lightdm/lightdm.conf.
satan
Wed Jun 12, 2013 12:47 am
obiwan wrote:Raspbian is a Debian Linux version, so as Debian, there is specific command to change settings (update-alternatives), to configure (dpkg-reconfigure) and to manage (apt-get, dpkg).
Dude you just changed my life. Thank you
mehstg
Wed Sep 04, 2013 8:12 pm
Sorry for the late reply, thanks for all your help. I found out what was stopping ratpoison from loading. Removing lxsession and adding 'exec ratpoison' to the .xinitrc file allowed ratpoison to start.
Thanks for all your help
Eshaan7
Wed May 23, 2018 9:46 am
Mine too!
Wed May 23, 2018 11:22 am
Mine too!
Please avoid resurrecting very old threads.
Software guy, working in the applications team.
Return to “Raspberry Pi OS”
