Hi everyone,
I have downloaded the Rapsbian Weather Station image (sep-17), burned it to the SD card, then inserted into the weather station board and when I boot the Weather Station it prompts me that "Failed to start the Apache HTTO server".
I also tried to update & upgrade but failed too.
I'm here providing you the links for both screenshots to see if you can help me:
https://i.imgur.com/ZJp2bXD.jpg
https://i.imgur.com/HCi1OoH.jpg
How can I fix the Apache error?
Thanks a lot from Argentina.
Cristián
Re: Failed to start the Apache HTTP server
Try running sudo apachectl config-test and post the output here.
This is the result of running 'sudo apachectl config-test':
/usr/sbin/apachectl: 208: /usr/sbin/apachectl: /usr/sbin/apache2: Exec format error
Action 'config-test' failed
The Apache error log may have more information
- DougieLawson
Take a look in /var/log/apache2/error.log.
Try sudo apt install --reinstall apache2
DMs sent on Bluesky or by LinkedIn will be answered next month.
When I do 'sudo apt install -reinstall apache2' I get the following prompt:
E: Comand line option 'r' [from -reinstall is not understood in combination with the other options.
You need to put two dashes in front of the reinstall option.
--reinstall
not
-reinstall
Thanks Rpdom!!
I finally solved the problem using the Raspbian Stretch Desktop image and then installing the weather station software manually.
Everything worked fine (except that I had to manually install MySQL) and now I have my weather station up and running (well, not NOW but yesterday night).
Now I'm ready to continue experimenting and learning using all the lessons.
Thanks again.
Kind regards,
Cristián
Thanks again.
Kind regards,
Cristián
- DougieLawson
You also need a new camera, because your one is crap.
And I thought it was my eyes/Christmas spiritYou also need a new camera, because your one is crap.
