kyljmn
Service won't start. code=exited, status=1/FAILURE
Mon Feb 24, 2020 2:56 am
I've been trying to get this service running for a while now, and I've been stuck with this problem for a week now.
These are the results for systemctl status:
pi@raspberrypi:~ $ systemctl status mtf-pi-scout
● mtf-pi-scout.service - The Measure the Future scout
   Loaded: loaded (/lib/systemd/system/mtf-pi-scout.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2020-02-24 10:35:49 PST; 15min ago
  Process: 1096 ExecStart=/usr/local/mtf/bin/scout (code=exited, status=1/FAILURE)
 Main PID: 1096 (code=exited, status=1/FAILURE)
Feb 24 10:35:48 raspberrypi systemd[1]: Started The Measure the Future scout.
Feb 24 10:35:49 raspberrypi systemd[1]: mtf-pi-scout.service: Main process exited, code=exited, status=1/FAILURE
Feb 24 10:35:49 raspberrypi systemd[1]: mtf-pi-scout.service: Failed with result 'exit-code'.
and These are the logs from journalctl:
Feb 24 10:32:40 raspberrypi dhcpcd[349]: eth0: fe80::1 is reachable again
Feb 24 10:32:49 raspberrypi sshd[1010]: Accepted password for pi from 192.168.1.5 port 2110 ssh2
Feb 24 10:32:49 raspberrypi sshd[1010]: pam_unix(sshd:session): session opened for user pi by (uid=0)
Feb 24 10:32:49 raspberrypi systemd-logind[268]: New session c3 of user pi.
Feb 24 10:32:49 raspberrypi systemd[1]: Started Session c3 of user pi.
Feb 24 10:32:54 raspberrypi systemd-timesyncd[257]: Synchronized to time server for the first time 162.159.200.123:123 (0.debian.pool.ntp.org).
Feb 24 10:34:02 raspberrypi sudo[1035]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/chmod 755 /usr/local/bin
Feb 24 10:34:02 raspberrypi sudo[1035]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Feb 24 10:34:02 raspberrypi sudo[1035]: pam_unix(sudo:session): session closed for user root
Feb 24 10:34:54 raspberrypi sudo[1048]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/service mtf-pi-scout restart
Feb 24 10:34:54 raspberrypi sudo[1048]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Feb 24 10:34:54 raspberrypi systemd[1]: Started The Measure the Future scout.
Feb 24 10:34:54 raspberrypi systemd[1058]: mtf-pi-scout.service: Failed to execute command: Permission denied
Feb 24 10:34:54 raspberrypi systemd[1058]: mtf-pi-scout.service: Failed at step EXEC spawning /usr/local/mtf/bin/scout: Permission denied
Feb 24 10:34:54 raspberrypi systemd[1]: mtf-pi-scout.service: Main process exited, code=exited, status=203/EXEC
Feb 24 10:34:54 raspberrypi systemd[1]: mtf-pi-scout.service: Failed with result 'exit-code'.
Feb 24 10:34:54 raspberrypi sudo[1048]: pam_unix(sudo:session): session closed for user root
Feb 24 10:35:08 raspberrypi sudo[1064]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl status networking
Feb 24 10:35:08 raspberrypi sudo[1064]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Feb 24 10:35:08 raspberrypi sudo[1064]: pam_unix(sudo:session): session closed for user root
Feb 24 10:35:43 raspberrypi sudo[1076]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/chmod 755 /usr/local/mtf/bin/scout
Feb 24 10:35:43 raspberrypi sudo[1076]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Feb 24 10:35:43 raspberrypi sudo[1076]: pam_unix(sudo:session): session closed for user root
Feb 24 10:35:48 raspberrypi sudo[1086]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/sbin/service mtf-pi-scout restart
Feb 24 10:35:48 raspberrypi sudo[1086]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Feb 24 10:35:48 raspberrypi sudo[1086]: pam_unix(sudo:session): session closed for user root
Please send help!
Re: Service won't start. code=exited, status=1/FAILURE
Mon Feb 24, 2020 5:30 am
Well, the "Permission denied" message should be a bit of a clue.
How about you show us your systemd service file and also the permissions on the program
ls -l /usr/local/mtf/bin/scout
What happens when you run the command manually, and what command do you type to do that?
Unreadable squiggle
kyljmn
Mon Feb 24, 2020 1:29 pm
This is what show's up when I us ls -l /usr/local/mtf/bin/scout:
-rwxr-xr-x 1 root root 4776016 Jan  4  2017 /usr/local/mtf/bin/scout
To restart the service I use
sudo service mtf-pi-scout restart
kyljmn
Mon Feb 24, 2020 1:49 pm
Also I'm new to linux. is this what you meant by systemd service file?
[Unit]
Description=The Measure the Future scout
After=postgresql.service
[Service]
Environment=LD_LIBRARY_PATH=:/usr/local/lib
WorkingDirectory=/usr/local/mtf/bin
[Install]
WantedBy=multi-user.target
