I am a newbie with the Pi, but I added a external drive to my Pi3 and when I try to move a file from my downloads folder to the new drive, I get the error cant be completed permission denied. I was trying to move a video file to the new drive, and again I am brand new to this so any help would be appreciated! Thanks!
Re: Permission denied
Run a command in the terminal to verify the file type of each storage drive connected to the Raspberry Pi computer. Use this command in the terminal:
File types FAT16/FAT32, and EXT4 will be usable out of the box. These file types does not require elevated user permissions to access the connected storage drives. File type NTFS I would say will require elevated user permissions. I haven't connected a NTFS drive to a Raspberry Pi computer in a long time. USB drives will use the FAT16/FAT32 file types. Boot media USB drives will use the FAT16/FAT32 file types. You will need to know how to use the command line to access the NTFS storage drive on the Raspberry Pi computer. From what I remember, you can install these 2 utilities to access the NTFS file system on a Linux computer. Run this command in the terminal:
Reboot the computer:
Check to see if you can access the external drive using the file manager. If you see the permission denied error when moving files to the storage drive. You will need to elevate user permissions. Here is a link to a guide that will show you how to access EXT4 partitions in Ubuntu:
How To Set Write Permission On ext4 Partition In Ubuntu Linux
https://itsfoss.com/set-write-permissio ... ntu-linux/
sudo fdisk -l
sudo apt install ntfs-3g-dev libfuse3-dev
sudo reboot
new drive is most likely "owned" by root
to verify run the command
on desktop versions of RPiOS the <drive mount point> is usually /media/pi/<usb drive label>
if not desktop version and you've specified the mount point via any method then use that
if its root then you need to change ownership of that mount point
run the command
then check again
after that try doing the file copy process again....
ls -la <drive mount point>
run the command
sudo chown -R <user:group> <drive mount point>
Some people be like:
- DougieLawson
It's nowt to do with the permissions of the mount point before you mount the drive. The NTFS driver has to compromise with the unix owner/group/world permission bits and will allow the mounter to have all permissions. If root mounts the drive for the pi user, you need to pass some extra options.
sudo mount /dev/sda1 /mnt -t ntfs-3g -o uid=pi,gid=pi
DMs sent on Bluesky or by LinkedIn will be answered next month.
