beta-tester
PIDFile= references path below legacy directory /var/run/ ...
Mon Oct 26, 2020 7:07 pm
hi,
when updateing (sudo apt update && sudo apt full-upgrade) my raspberry pi (RPi4B)
i see in the /var/log/syslog the following messages:
Oct 26 19:26:58 raspberry systemd[1]: Starting Daily apt download activities...
Oct 26 19:26:59 raspberry systemd[1]: apt-daily.service: Succeeded.
Oct 26 19:26:59 raspberry systemd[1]: Started Daily apt download activities.
Oct 26 19:40:06 raspberry systemd[1]: Starting PackageKit Daemon...
Oct 26 19:40:06 raspberry PackageKit: daemon start
Oct 26 19:40:06 raspberry systemd[1]: Started PackageKit Daemon.
Oct 26 19:40:32 raspberry systemd[1]: Reloading.
Oct 26 19:40:32 raspberry systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Oct 26 19:40:32 raspberry systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Oct 26 19:40:32 raspberry systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Oct 26 19:40:33 raspberry systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Oct 26 19:40:33 raspberry systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
Oct 26 19:40:33 raspberry systemd[1]: Reloading.
Oct 26 19:40:33 raspberry systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Oct 26 19:40:34 raspberry systemd[1]: Reloading.
Oct 26 19:40:34 raspberry systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly.
Oct 26 19:40:34 raspberry systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
Oct 26 19:40:34 raspberry systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
i am wondering what that message:
will mean for the services rpc-statd, smbd, nmbd...
any idea, how to fix it?
Re: PIDFile= references path below legacy directory /var/run/ ...
Mon Oct 26, 2020 7:12 pm
It should get fixed by the DebIan maintainers in Bullseye (next version after Buster due in the Autumn of 2021). The message is informational, so feel free to ignore it (unless you want to start hacking service files that are part of the packages you've installed (or were pre-installed)).
DMs sent on Bluesky or by LinkedIn will be answered next month.
beta-tester
Mon Oct 26, 2020 7:15 pm
so it's nothing to worry about... no malfunctioning service?
Mon Oct 26, 2020 7:46 pm
I get the same junk messages on my system and nothing bad happens because of them.
bls
Mon Oct 26, 2020 7:47 pm
Correct. Perturbing the first time you see them, and annoying after that. But no malfunctioning.
Pi tools:
Quickly and easily build customized exactly as-you-want SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure IPSEC/IKEV2 VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
beta-tester
Mon Oct 26, 2020 8:16 pm
thank you.
