pipuppy
How to delete a read-only directory in Rasbian Bookworm release.
Tue Nov 21, 2023 11:16 am
I recently came back to using my raspi 400 after a break of almost a year. I also re-flashed the SD card to take advantage of the newer Bookworm release of raspbian and for the most part everything works as I remeber except for the "rm" trminal command.
I would like to remove an unwanted "snap" directory which remained after removal of the snap-store package.
I Googled for information on how to remove an unwanted directory in Debian linux and the pages I have read describe variants of the rm command which I have been trying.
I open a terminal window, navigate to the "/" directory and then attempt to remove the unwanted "snap" directory using
sudo rm -r snap
Each time I try to delete the unwanted directory I get the following error message which keeps repeating for every file in the directory and sub directories.
rm: cannot remove 'snap/core22/867/usr/lib/aarch64-linux-gnu/libzstd.so.1.4.8': Read-only file system
I had a go at changing file permissions with...
sudo chmod +rwx snap
and then
sudo rm -r snap
and other variations of the rm command but the directory refuses to delete.
I could just re-flash but thats the cowards way out and I wont learn anything from my mistakes :D
After a year away from using terminal commands I have become very rusty and suspect I am missing something here and would appreciate some pointers as to which terminal command I should be using to delete an unwanted directory :oops:
Pipuppy
B.Goode
Re: How to delete a read-only directory in Rasbian Bookworm release.
Tue Nov 21, 2023 12:20 pm
sudo rm -r snap
and then
sudo rm -r snap
Pipuppy
If this were my issue to resolve I would be investigating why the Operating System thinks it has a Read-Only root filesystem. (This is a different level of protection to having a read-only file or a read-only directory.)
I don't think that is the standard behaviour/configuration of RasPiOS Bookworm.
Are you running some other 'rasbian' OS, or have you made some change subsequent to flashing it to the microSD card?
Beware of the Leopard
neilgl
Tue Nov 21, 2023 12:33 pm
Maybe
rm -rf snap
kerry_s
Tue Nov 21, 2023 12:41 pm
you sure you removed, snaps are mounted.
do a double check.
apt search ^snap | grep installed
clean
sudo apt -y autoremove && sudo apt -y clean && sudo apt -y purge ?config-files
cleverca22
Tue Nov 21, 2023 1:15 pm
but is it even the root that is read-only?
snaps work by mounting something, so it may actually be a snap that is mounted read-only
in that case, the answer is to just umount it, or tell snapd to stop doing whatever its doing, or uninstall snap
B.Goode
Tue Nov 21, 2023 1:26 pm
I am content for the user to find that is not the case.
My response was based on the disparity between the topic Title: How to delete a read-only directory, and the error
reported in the message text: rm: cannot remove 'snap/core22/867/usr/lib/aarch64-linux-gnu/libzstd.so.1.4.8': Read-only file system
That seemed worth drawing attention to for investigation. It is good that other volunteers can provide more focussed advice.
pipuppy
Wed Nov 22, 2023 11:06 am
Hi again,
First of all my thanks to all of you for taking the time to respond to my request for help.
I am pleased to report that following the advice of kerry_s the problem has now been resolved.
kerry_ advised...
and...
I dont fully understand exactly where I went wrong but it is now clear that some residue of the snap store was still present after using apt-get remove snap-store command.
After reading this webpage...
https://linuxsimply.com/linux-basics/pa ... ove-purge/
I strongly suspect that I had only removed the snap-store package and possibly left behind snapd, the snap-core or both and that was preventing the unwanted directory from being attacked.
Because the entry in the applications menu had been removed I had wrongly assumed that the snap-store bundle had been fully removed :oops:
After following kerry_s instructions the problem is now resolved and I will now know what to look for if I run into this problem again in the future so, my thanks to kerry_s for pointing me in the right direction.
Regards,
pipuppy
