bls
NVME performance test
Sun Feb 04, 2024 5:03 pm
Results from my early/quick NVME performance test
Hardware: Pi5, Geekworm X1001, Kingston NV2 500GB SSD
Test:
# all run as root
rm -f bar.img
echo 1 | tee /proc/sys/vm/drop_caches
time cp foo.img bar.img
Test results:
Nothing in config.txt: 33.266  0.040   7.153
                       33.282  0.091   7.133
                       33.266  0.043   7.051
pciex1 (only):         33.286  0.048   7.107
                       33.367  0.047   7.080
                       33.321  0.047   7.158
pciex1, pciex1_gen=2   33.425  0.040   7.047
                       33.260  0.043   6.983
pciex1_gen3            18.070  0.046   6.900
                       18.754  0.068   6.819
                       18.478  0.041   6.841
pciex1, pciex1_gen=3   18.077  0.050   6.779
                       18.386  0.059   6.818
                       18.032  0.059   6.847
Conclusions:
  • Apparently "pciex1_gen=n" implies "pciex1"
  • pciex1_gen=3 is FAST
Pi tools:
Quickly and easily build customized exactly as-you-want SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure IPSEC/IKEV2 VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
bls
Re: NVME performance test
Sun Feb 04, 2024 7:37 pm
And, for comparison...
NVME system disk, Kingston A400 connected to USB3 Hub:
44.998  0.028  7.320
44.265  0.053  7.008
NVME system disk, Kingston A400 directly into Pi5 USB3 port:
47.089  0.053  6.959
45.543  0.053  6.959
44.446  0.066  6.963
Unsurprisingly, tests done when running on a Kingston A400 system disk were similar to the above.
The variability in the last test (Kingston A400 directly into Pi5 USB3 port) is curious :roll:
Pi tools:
fanoush
Sun Feb 25, 2024 8:05 am
You could add "sync" call to the time, cp does not wait until everything is written so if there is enough ram you are measuring only reading, not writing. And BTW, how big your foo.img file actually is?
bensimmo
Sun Feb 25, 2024 10:52 am
It amazing how we're all saying it blaming fast when it is actually amazingly slow (in in PCIE4) compared to any recent era 5/6 years PC or laptop, when NVME M.2. started to be use
Even my laptop is at least twice as fast but then it uses an extra lane to the Pi and these are excruciatingly slow compared to modern NVMe setup with all lanes and PCIE4 or5.
That's in benchmarks, in the real world use you don't really notice that pcie2 to 3 jump in a single lane nor that PCIE3 to 4.
Unless your transferring a clone of one drive to another.
Anyway, I came to say there is a Iong topic on this comparing different boards and settings and the errors people are seeing.
bls
Sun Feb 25, 2024 2:16 pm
Yea, this was just a "smoke test", I was trying to get *indicative* data, not scientifically perfect reproducible data. foo.img is unfortunately long gone, but I ISTR it was about 5-6GB.
Sorry for the lack of precision. :roll:
Pi tools:
bls
Sun Feb 25, 2024 2:20 pm
Absolutely agree, but the disk I/O performance improvement on the Pi5 is pretty impressive, and it's also quite impressive for a sub-$100 highly flexible computer.
And, it's worth noting that there are other ways to improve performance in this highly contrived benchmark such as using a copy-on-write file system (btrfs), where the copy is instantaneous.
Lastly, disk I/O is a small (but obviously important) piece of the total performance picture.
Pi tools:
bensimmo
Sun Feb 25, 2024 2:40 pm
Could you do a similar 6GB transfer but with loads of random small files, that would be more interesting, only as I don't do a lot of 6GB file transfers.
Where to get that number from, cookies after a day or two of tracking us, browser cache files?
By the way, I'm assuming the first column is time, as it get quicker, more than I expected on the switch from USB3 to standard PCIe, assuming drives are OS similar spec. (edit, ah a while generation of age newer being PCIE4, yet both are £35 on Amazon for the ~500GB versions.) bargain for the nvme once you have a adaptor board.
But what are the other two. I know not important, just curious.
bls
Sun Feb 25, 2024 3:10 pm
I'll look into doing a bit more testing, as you've suggested, but have a few other TODOs ahead of it :roll:
As far as the 3 columns, they are the 3 figures output by the time command, rotated around from vertical to horizontal formatting: real, user, sys, which are (AIUT):
real: wall-clock time
user: user-mode time consumed
sys: system-mode time consumed
From `man bash`: If the time reserved word precedes a pipeline, the elapsed as well as user and system time consumed by its execution are reported when the pipeline terminates.
Pi tools:
