slider81
low reset(pin RUN) voltage level
Wed Sep 18, 2024 8:47 am
Hello, everyone.
I have a yd -rp2040 board. When connected to a computer via usb with the "boot" clamped, my internal bootloader does not start.At the same time, the reset(RUN) voltage has a low level.Is there any way to reset this cpu bits state without using a debugger?
gmx
Re: low reset(pin RUN) voltage level
Mon Nov 18, 2024 7:12 pm
Which version or color of yd -rp2040 board ?
gmx
Tue Nov 19, 2024 9:10 pm
Just a hint, these boards have a Reset button, you need to keep pressed the BOOT button and shortly press RST button, then release BOOT.
Return to “Other RP2040 boards”
